Subpanel vs breakers in main panel
   / Subpanel vs breakers in main panel #31
And your insurance won't pay when something burns down because it wasn't code or done as required by law. Which is best case if someone doesn't get killed.
This is often stated, but examples are never forthcoming.
   / Subpanel vs breakers in main panel #32
That does not fly in all areas, like has been mentioned there is no codes or inspections in my town. So what are you following? The national electric code i guess but if no one checks and there is no code enforcement i dont know if that would hold up in court?
   / Subpanel vs breakers in main panel #33
20+ years in the electric industry has taught me a healthy respect for power. People here either know what they're talking about or they don't. EITHER ONE can easily get someone WHO DOESN'T know what they're doing in serious trouble. I'm amazed anyone would take that chance when working with electricity. Oh, but I'd rather look smart here giving advice to someone without regard to their skill set or the consequences. Ignorance is bliss, and since you'll never know if this fella burns down his shed or his kid dies because the floor was wet, you'll go blissfully along.
Settle down. The guy asked for advice and people are offering it. That's the point of these forums. I'm pretty sure he's trying to do the right thing or he wouldn't have bothered to ask.
   / Subpanel vs breakers in main panel #34
does a sub panel in your house need to have a ground rod to it? Im talking i have a 200A pannel in house and on an addition they had a sub panel that is 40A. I replaced it with current box and romex and did it just like it was. Neutral and ground are not bonded and it is on a 40A breaker and has 2, 20A breakers in the sub. There is no ground rod though? Is that right? or do i need a ground rod to the sub?
Since I don't think anyone answered your question, I will. The grounds and neutrals need to be kept separate in your sub panel and no ground rod needed. You'd need the ground rod if the sub panel was in a remote building.
   / Subpanel vs breakers in main panel #35
If this thread was to be a movie, we would have to get Sam Peckinpah back from the grave to be the director
   / Subpanel vs breakers in main panel #36
First paragraph of the OP's first post,, " It is a shed he is powering" IE remote
   / Subpanel vs breakers in main panel #38
My neighbors just called me over to look at a problem they have in a remote bunkhouse. After a nearby lightning strike, they had failures of two heaters, a DVD player, a flat screen TV, and a satellite receiver which were all off during a thunderstorm. All of the heaters had the electronic touchpad controls with remote controls. I explained to them that all those things being "off" was a misnomer. They must remain powered since they have to be able to communicate with the remote. The remote control receiver is on as long as the appliances are plugged in.
I also looked at their sub-panel box and told them that the fellow who wired the box was not an electrician because the neutrals and grounds were tied together. The box did not have a ground rod either. I explained to them that the friend who built their structure was very good, but he just did not understand the fine points of electrical code. I suggested that they not take my word for it, but rather to get a qualified electrician to look at the wiring. I also told them that no surge protector or wiring would protect them from a direct lightning strike, but that properly wired panels with the proper grounding plus good surge protectors could save the equipment in a near-strike environment.
   / Subpanel vs breakers in main panel #40
Not much.
What amazes me are the people who are so rules compliant they can't use the restroom without checking building code.
The house I live in now is 100+ years old. The electric service is from the 70s. And it hasn't burned down yet. None in my neighborhood have yet.
It amazes me how risk adverse some people are.
You maybe happy claiming you are just too much of a "He Man" being obvious to all so strong , fast and smart to avoid perils.
Problem is you have not checked with the local fire department, paramedics, police, hospital staff, physiotherapy clinics, long term care homes and funeral homes. Being a jackleg mechanic, jackleg electrical or jackleg builder will sooner or later catch up with you or someone else. You would also find yourself fired and escorted from the aviation, nuclear, medical, manufacturing and construction sites.
If you have no regard for your own safety, fine. Just don't harm anybody else or expect everybody else to pay.
2007 TROXELL KILL/TRANSPORT TRAILER (A50854)
2007 TROXELL...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2006-2009 Ford 4x4 Pickup Truck Bed (A49461)
2006-2009 Ford 4x4...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
