Subpanel vs breakers in main panel
   / Subpanel vs breakers in main panel #13
Here in Idaho they allow the tied breaker to feed another building BUT that building has to have a toggle switch (or decora switch) at the first junction box that will cut off all power to that building. It doesnt need to be a breaker, but a switch is required (or 2 switches in a tandem circuit). Anything more requires a subpanel.
Personally, since the trance is the most expensive part of this operation, id run a 40 amp , 240 circuit to a 8 space, $30.00 panel. This will give you more options in the future. And wont cost that much more overall. Like i said, the tranch and trenching labor is the most expensive part. so do it only 1 time
Yes I think I'm spending more time trying to out clever myself than it would take to just put in the subpanel. I haven't put anything in this building yet and it's already too small, so I'm guessing the electric will follow the same pattern.
   / Subpanel vs breakers in main panel #15
Rock Knocker has a good handle on the topic.
You will be happiest with four #4 conductors to a 60 amp panel in the shed. Requires a ground rod at the shed sub panel and the bond opened between the ground bar and neutral bar. To keep neutral current off the ground system.
   / Subpanel vs breakers in main panel #16
does a sub panel in your house need to have a ground rod to it? Im talking i have a 200A pannel in house and on an addition they had a sub panel that is 40A. I replaced it with current box and romex and did it just like it was. Neutral and ground are not bonded and it is on a 40A breaker and has 2, 20A breakers in the sub. There is no ground rod though? Is that right? or do i need a ground rod to the sub?
   / Subpanel vs breakers in main panel #18
compared to a sub-panel, an MWBC requires less wire -- and wire is expensive these days. for a pair of 20A circuits using an MWBC, you need qty 2 #12 black, qty 1 #12 white, and qty 1 #12 green. an MWBC does require a switch at the detached structure, which could be as simple as an A/C cutoff switch mounted in a plastic box.
a sub-panel is going to require more infrastructure,and is therefore costlier. heavier wire for the feeder, two ground rods, the panel itself, breakers, ground bars, etc. a panel does give more options in terms of circuit separation, and growth.
Wrooster
   / Subpanel vs breakers in main panel #19
Sub panel at the out building or not. There should be a ground rod driven at the outbuilding and the ground attached.
   / Subpanel vs breakers in main panel #20
If you used a 20 amp 220v breaker and a small (2 space?) subpanel, that is also all that you would need...
Aaron Z
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
1270 (A50490)
1270 (A50490)
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
Unused 2025 CFG QK18R Mini Excavator (A49461)
Unused 2025 CFG...
TANNKO  130BBL VAC TRAILER (A50854)
TANNKO 130BBL VAC...
