Shop and storage barn
/ Shop and storage barn
This stump put up a fight, but the mightly Cat finally won. Here's the stump as I pushed it out, and the space sans-stump.
And here are the final results.
The first two show the area by the stump cut down as it should be.
The third picture shows where the dirt needs to go. You can see the pile in the back on the far right and the dozer behind it ready for another push.
Finally, the area graded out.
/ Shop and storage barn #23
Nice progress Hayden,
I see you've thought pretty much about everything including heating and AC. My barn is now complete and I'm ready to start laying out the shop part. I have no AC and even though it's a fully insulated metal building, it gets pretty hot in there but not unreasonable. I'm sure it will be cold in the Winter too. Right now I'll add a large industrial fan for the Summer and deal with heating later.
You will not be sorry in the size you chose, because it will fill up easily, I'm sure. I'd like to see what kind of shelving or cabinets (if any) you will install? Is the framing and such the next step for you? Seems like you have perfect weather right now.
Yes, framing is next, and a minimal crew started today. They got the sill plate in place and bolted down and cut the studs for one of the 60' walls.
I'll have heat, but no AC. It's rare that it gets hot enough here to warrant it, and it always cools off nicely at night. Beside, I don't have enough power for AC, so we live with fans. Today was an example of about the hottest it gets, and it might have broken 90. Now it's in the low 70's with a nice breeze.
I haven't figured out cabinets yet. I've got one of those double door, full height metal cabinets in the garage now, and I'm thinking of just getting more of those. I'm also going to consider some industrial rack shelving. I'm talking about the stuff in warehouses where they stack pallets to the ceiling on adjustable shelves. I'm thinking it might be a good way to store infrequently used implements
The crew spent yesterday and today framing walls on the slab. Here are a bunch of them ready to put up, which I think we will start doing tomorrow.
The last picture shows the underground power line all back-filled and raked.
I think on Monday we will have the crane truck set the beams.
While all this has been going on, I've been busy working on the solar system.
http://www.tractorbynet.com/forums/projects/122792-solar-electric-project.html#post1412671
I had to go down to Boston for the day today, but look what happened while I was away :D . I should go away more often.
The first pic shows the new building from the house. For such a large structure I'm pretty happy with how tucked away it turned out to be.
The next picture shows the big door to the shop with my wife for perspective. The deck above is 12' and the door is 10' high.
Next is the inside of the shop. It's a BIG room.
The next are of the garage space, first from the inside looking out through two of the four doors, then from the ouside showing all four door openings.
More progress over the past few days. The big action has been the installation of the beams. There are two steel beams in the shop to provide a clear work space. In the garage section there are three laminated beams.
The first picture shows the steel beams preped and ready to go up. Those are 2x12's bolted to both sides. The floor joists will then be attached with joist hangers.
Next shows the lifting straps being attached.
Beam going up
Beam coming down.
Next are the laminated beams going in.
The beams came 5 1/2" short, so we just centered them for now. We'll probably build out the end posts a bit to make up the difference.
And finally the big beam, going up and up, then down into place.
The last picture is looking in the shop door adn you can see the two steel beams in place.
/ Shop and storage barn #30
I was always told, "Measure twice, cut once". Just wish I would follow that advice. :rolleyes:
Hope things work out for you.
Yea, it's a bit frustrating. These are manufactured beams, and the engineer forgot to add the thickness of one of the walls, hence the 5 1/2" shortage. We could have sent them back and waited for replacements, but I think it will all work out fine. They are designed to sit on top of 3 1/2" posts, so we are 1 1/2" short of meeting the structural requirement. That can be made up by fattening one of the posts with a sister 2x6.
/ Shop and storage barn #32
Was it cut too short, ordered pre cut or did you buy the standard length and not realize how long you needed it?
I agree that building up the wall to support it is your only real option short of buying a new beam.
The building looks good and as always, it's impressive to see your progress!!
Eddie
They were ordered pre-cut. Somewhere between ordering and cutting it came out short. I don't know for sure, but my guess would be that the order got placed incorrectly. Exactly where things broke down I'm not sure. If I were doing this day in and day out I'd be more motivated to sort out exactly what went wrong in the interest of preventing it in the future, but in this situation I think it would just be a witch hunt and possibly damage relations with my suppliers and builder, so I'm just looking at how to move forward. I suspect my builder will be more interested in figuring out what went wrong. I know he was planning a "what the heck" visit to the supplier.
/ Shop and storage barn #34
Too bad. I thought that maybe it was something different, but it sounds like somebody droped the ball and should make it right. If I had a choice, I would want the proper length beam in there. It's what you paid for, and you will have to live with the results forever. Taking the time to do it right and make it like you are paying for it to be is more important then losing a few days or pissing off the people you've hired to do it the way you want it done.
The reason you hire a General Contrator is to make sure these things don't happen, and when they do, to fix them. I'm curious what he's going to do to make this right. I don't think building up the wall to make up the difference is my idea of making it right, but a quicky fix to an oops. If you had made the mistake, then that is totally different and something that you can decide to live with or not. Since you didn't make the mistake, you shouldn't have to pay for it to be done wrong.
Around here, a standard length Laminated Beam is around $200, and after it's delivered or you pick it up, you cut it to length. I always cut them myself when I use them, which isn't often.
Eddie
Hi Eddie,
In principal I agree with you completely and often take exactly the position you describe. Right now I have two options. a) build out the posts and keep moving, or b) re-order the beams and essentially shut down for 1-2 weeks which is the time it will take to get them replaced. Given those options, I'm going to keep moving ahead. Although not the original plan, fattening the posts will be structurally equivalent and yield almost zero compromise in appearance (and it's an unfinished garage anyways). I neglected to mention that there is an option C which might well be the best, and that's to simply add angle brackets where the post and beam meet. The guy doing the engineering is going to evaluate both to see how they compare. If we used brackets there would be no appearance impact.
Anyway, to me, structural integrity is non-negotiable, the appearance is negotiable, and a week or two matters. If we can get structural integrity with a slight change to the appearance and not shut down for a week, then that's what I'll pick. I should know more in the next day or two and keep you posted
By the way, some might wonder why things would "essentially shut down". It's because the next step is the deck over the beams, and if the beams are being replaced that they obviously can't build the deck on top of them. They've pretty much already done everything else they can at this point other than one more course of sheething.
Oh, and don't worry, I won't pay for whatever it takes to fix this.
OK, here's where things are at the end of the week.
First, the short beams. It was all much ado about nothing. They need 1 3/4" of post on each end to meet the structural objective. We're got 2 3/4 on each end, so they are fine the way they are, no need to the fatten posts or anything. Dodged that bullet!
The rest of the week the crew got all the floor joists hung and about 1/3 of the deck installed. We used the tractor and forks to lift the deck material up to the second floor. The loader can only lift to about 10' and the deck is 12', but the gang was able to lean over a pull up the sheets. It beat the heck out of humping them up a ladder!
I don't have pictures of loading the deck material, but here are some shots of the inside. It's going to be a great work space.
A little later I climbed up on the deck to check out the view. Not bad, and a whole new perspective from what I've been looking at for the past 48 years.
/ Shop and storage barn #38
Hayden that building is incredible, so well built. I really like the way the beams are set and how the 2nd floor joists attach to them.This is how I will build next time.
Thanks guys. It will be a few days before I can post more pictures, but at this point the deck is finished, the walls are all sheathed, and the ridge pole is up. The next major milestone will be a complete roofing system.
Stay tuned
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Cattle Feeder (A65640)
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
Round Bale Livestock Feeder (A66408)
Round Bale...
2018 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2018 FREIGHTLINER...
