Rod end broken off on loader hydraulic
   / Rod end broken off on loader hydraulic #1
A1plus
I was hauling a bit too much weight with my forks on the loader. The block at the end of the rod broke off. Do I need to get a new cylinder or can I just get this welded back on. And what type or weld would it need?
   / Rod end broken off on loader hydraulic #2
A picture would be helpful to give better advice, but I would say you can just weld it back on.
Grind a good bevel on it and throw some solid weld beads.
Me, done mostly stick welding, would just use some 6013 rods and weld it.
That's how I did it on my homemade loader.
Thanks I am going to get it welded back together
   / Rod end broken off on loader hydraulic #5
Weld it. I broke the ball end off of my top link, tore the ball cage open. I cut the broken ball cage off of the shaft end and prepared the shaft for welding. I ordered a china replacement ball end from Amazon, welded it on a couple years back and have had no issues since.
KBH 25T Tender (A56438)
KBH 25T Tender...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
2025 GPS Trailers (A56859)
2025 GPS Trailers...
Landhonor HD Wheel Balancer (A59814)
Landhonor HD Wheel...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
