Rod end broken off on loader hydraulic
   / Rod end broken off on loader hydraulic #1
A1plus
I was hauling a bit too much weight with my forks on the loader. The block at the end of the rod broke off. Do I need to get a new cylinder or can I just get this welded back on. And what type or weld would it need?
   / Rod end broken off on loader hydraulic #2
A picture would be helpful to give better advice, but I would say you can just weld it back on.
Grind a good bevel on it and throw some solid weld beads.
Me, done mostly stick welding, would just use some 6013 rods and weld it.
That's how I did it on my homemade loader.
Thanks I am going to get it welded back together
   / Rod end broken off on loader hydraulic #5
Weld it. I broke the ball end off of my top link, tore the ball cage open. I cut the broken ball cage off of the shaft end and prepared the shaft for welding. I ordered a china replacement ball end from Amazon, welded it on a couple years back and have had no issues since.
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
Giyi 44" Mini Grapple (A53316)
Giyi 44" Mini...
2009 Ford F-250 Ext. Cab Enclosed Service Truck (A55788)
2009 Ford F-250...
2015 Freightliner M2 106 Ambulance (A55788)
2015 Freightliner...
2017 GMC SIERRA 1500 (A53843)
2017 GMC SIERRA...
