3-Point Hitch Replacing hitch pins with bolts
   / Replacing hitch pins with bolts #21
Some of them snap open so hard that they'll bite you then too.
   / Replacing hitch pins with bolts #22
I keep all my pins locked with small sized plastic ties. It's worked fine so far even when hogging blackberries along a ditch through my place. The first time I go cut that stuff each season I back the brushhog down into the berries until I can't see it and the thorns are at my back so it'll pull out the cuttings, Haven't lost a pin since tying them all closed.
   / Replacing hitch pins with bolts #23
I used to lose linchpins from my bucket pivot pins. Then I inserted them from bottom up and never lost them again. Don't know why they stay in though.
   / Replacing hitch pins with bolts #24
Growing up, my Dad made it sound like those pins were $20 each. If we lost one we were in deep *****. He even put short chains on them so we couldn't set them on something and drive off.
Now I just carry a spare, because whenever I have a spare anything, the original never gives a problem. :)
   / Replacing hitch pins with bolts #25
We should all note this proper application of Murphy's Laws.
The one I can't seem to avoid is Murphy's Seventh Law:
Whatever you are setting out to do, you will have to do something else first.
   / Replacing hitch pins with bolts #26
:thumbsup:x2
   / Replacing hitch pins with bolts #27
A bit off topic, but here is the photo that you may be referring to.
The washer on the right has a black, heavy duty lynch pin. They are strong.
Just using a bolt through the two washers might work.
Using a nut instead of one of the washers would also work. It would seem to be a bit rigid. I'd use a nut on one side and a washer on the other if that was the choice.
If you weld the nut to the bolt's thread then it would be permanent - until the O/A torch is used.
Thanks for that suggestion!!!! :thumbsup:
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A56438)
2017 Ford F-550...
9000 (A47477)
9000 (A47477)
