3-Point Hitch Replacing hitch pins with bolts
/ Replacing hitch pins with bolts #21
Some of them snap open so hard that they'll bite you then too.
/ Replacing hitch pins with bolts #22
I keep all my pins locked with small sized plastic ties. It's worked fine so far even when hogging blackberries along a ditch through my place. The first time I go cut that stuff each season I back the brushhog down into the berries until I can't see it and the thorns are at my back so it'll pull out the cuttings, Haven't lost a pin since tying them all closed.
/ Replacing hitch pins with bolts #23
I used to lose linchpins from my bucket pivot pins. Then I inserted them from bottom up and never lost them again. Don't know why they stay in though.
/ Replacing hitch pins with bolts #24
Growing up, my Dad made it sound like those pins were $20 each. If we lost one we were in deep *****. He even put short chains on them so we couldn't set them on something and drive off.
Now I just carry a spare, because whenever I have a spare anything, the original never gives a problem. :)
/ Replacing hitch pins with bolts #25
We should all note this proper application of Murphy's Laws.
The one I can't seem to avoid is Murphy's Seventh Law:
Whatever you are setting out to do, you will have to do something else first.
/ Replacing hitch pins with bolts #26
:thumbsup:x2
/ Replacing hitch pins with bolts #27
A bit off topic, but here is the photo that you may be referring to.
The washer on the right has a black, heavy duty lynch pin. They are strong.
Just using a bolt through the two washers might work.
Using a nut instead of one of the washers would also work. It would seem to be a bit rigid. I'd use a nut on one side and a washer on the other if that was the choice.
If you weld the nut to the bolt's thread then it would be permanent - until the O/A torch is used.
Thanks for that suggestion!!!! :thumbsup:
Towable Chemical Applicator Sprayer (A59228)
Towable Chemical...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2015 Ford F-250 Pickup Truck (A59230)
2015 Ford F-250...
EZ loader trailer (A56857)
EZ loader trailer...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
