Recommendation for 3-point forks
   / Recommendation for 3-point forks #1
Spike56
Platinum Member
Lexington, Texas
JD 2355
I am looking for a decent 3-point set of forks. My application is to leave my front-end loader on and be able to haul some tools (shovels, chain saw....) along. I wouldn't mind if someone had a ready made "basket", but I have not seen one ? So, will construct my own pallet to use. I see prices all over the spectrum ? Any recommendations?
   / Recommendation for 3-point forks #2
I am currently considering a 3 point to ssqa adapter to use my existing pallet forks off the rear. There are direct 3 point pallet forks out there, but not nearly as many as ssqa forks.
   / Recommendation for 3-point forks #3
I built a three-point adapter for the JD hook and pin style pallet forks.
Curious why you wouldn't just use a carryall for transporting tools, etc. on the back end?
That is what I am looking for. But, I do not have any method to attach it to the 3-point ? Never did a search for "carry-all" ? I need to buy something ready made, can do the lumber part, but need the metal part AND I do not have a quick attach, so hopefully easy to hook / unhook ?
   / Recommendation for 3-point forks #5
I bought my County Line carryall frame from Tractor Supply and did the wood part myself. If you look close, you can see that I also added a receiver hitch to pull my utility trailer behind. Here is what the bare frame looked like (except for the green paint).
Okay, thanks for answering a dumb question ! This looks like what I need and then add my own wood / box. I checked on Tractor Supply website. There are (2) different ones ? Weird ? At least the numbers following the product seem different ?
   / Recommendation for 3-point forks #7
They appear to have slightly different top link connections, so you might want to think about which one works best for your tractor. Sounds like you're not using a quick hitch, so it may not matter. The one I bought from there was not quick hitch compatible, so I had to make an adapter.
No quick hitch here. I had bought a quick hitch for the front years ago, but it did NOT help that much removing the bucket and putting on a hay spear takes two grown men and a small boy to do. :( If everything is PERFECTLY level, works ok but ....
Thanks for the advice. I *really* need something on the rear to "carry all".
   / Recommendation for 3-point forks #9
I use a three-point Double-Fork Carrier from Hay King for all sorts of material and tool handling. Heck, I even use it to move round bales of hay! :)
Very solid and well-built. You can certainly build whatever type of bucket or platform to fit on it.
Hay King is a small business located in Taylor, Texas. I have several of their products. Highly recommend them. More info here: Hay King Loaders
   / Recommendation for 3-point forks #10
Everything Attachments makes a nice set of rear forks. Lots of adjustment for the top link to work with a QH too.
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
Giyi Mini Auger (A57149)
Giyi Mini Auger...
LEINBACH 1R CULTIVATOR (A52708)
LEINBACH 1R...
1998 PETERBILT 377 (A58214)
1998 PETERBILT 377...
PALLET OF 11 BARBED WIRE ROLLS (A58216)
PALLET OF 11...
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
