Recommendation for 3-point forks
/ Recommendation for 3-point forks #1
Spike56
Lexington, Texas
JD 2355
I am looking for a decent 3-point set of forks. My application is to leave my front-end loader on and be able to haul some tools (shovels, chain saw....) along. I wouldn't mind if someone had a ready made "basket", but I have not seen one ? So, will construct my own pallet to use. I see prices all over the spectrum ? Any recommendations?
/ Recommendation for 3-point forks #2
I am currently considering a 3 point to ssqa adapter to use my existing pallet forks off the rear. There are direct 3 point pallet forks out there, but not nearly as many as ssqa forks.
/ Recommendation for 3-point forks #3
I built a three-point adapter for the JD hook and pin style pallet forks.
Curious why you wouldn't just use a carryall for transporting tools, etc. on the back end?
That is what I am looking for. But, I do not have any method to attach it to the 3-point ? Never did a search for "carry-all" ? I need to buy something ready made, can do the lumber part, but need the metal part AND I do not have a quick attach, so hopefully easy to hook / unhook ?
/ Recommendation for 3-point forks #5
I bought my County Line carryall frame from Tractor Supply and did the wood part myself. If you look close, you can see that I also added a receiver hitch to pull my utility trailer behind. Here is what the bare frame looked like (except for the green paint).
Okay, thanks for answering a dumb question ! This looks like what I need and then add my own wood / box. I checked on Tractor Supply website. There are (2) different ones ? Weird ? At least the numbers following the product seem different ?
/ Recommendation for 3-point forks #7
They appear to have slightly different top link connections, so you might want to think about which one works best for your tractor. Sounds like you're not using a quick hitch, so it may not matter. The one I bought from there was not quick hitch compatible, so I had to make an adapter.
No quick hitch here. I had bought a quick hitch for the front years ago, but it did NOT help that much removing the bucket and putting on a hay spear takes two grown men and a small boy to do. :( If everything is PERFECTLY level, works ok but ....
Thanks for the advice. I *really* need something on the rear to "carry all".
/ Recommendation for 3-point forks #9
I use a three-point Double-Fork Carrier from Hay King for all sorts of material and tool handling. Heck, I even use it to move round bales of hay! :)
Very solid and well-built. You can certainly build whatever type of bucket or platform to fit on it.
Hay King is a small business located in Taylor, Texas. I have several of their products. Highly recommend them. More info here: Hay King Loaders
/ Recommendation for 3-point forks #10
Everything Attachments makes a nice set of rear forks. Lots of adjustment for the top link to work with a QH too.
/ Recommendation for 3-point forks #11
I bought the King Kutter carry-all and bolted 2x12 boards to it to make a working platform and wood carrier. It has worked perfect for me.
King Kutter Carry All - CA-YK | Blain's Farm & Fleet
I also have an adapter so I can use it on the loader instead of the 3pt.
/ Recommendation for 3-point forks #12
I bought a three point set of forks for my B7610 back ~ 2009.
Works well but it was only about $100 back then.
From Agri-supply. link
/edit
Carries a pallet mounted 275 gallon Tote cage very well. Got the tote and pallet for free, thus I was only out about $100.
/ Recommendation for 3-point forks #13
You might need a hydraulic upper link to make forks work effectively. I went with the JD QA loader plates and then got the QA forks. Switch out in less than a minute. But having the loader bucket PLUS rear forks might be actually what you need.
/ Recommendation for 3-point forks #14
From Agri-supply.
I bought them at about $140... works for the pallets of firewood. Not sure I would buy them for the going rate at $320
Yes hydraulic top and side link are a must have with this!!!!
Yes ! Looking at Hay King ! Taylor only 45 minutes away from me.:) Long ago had a renovator from them. Was solidly built.
Did you do any modifications / make into a carry-all ? Maybe best that I build my own pallet ? What say you ?
/ Recommendation for 3-point forks #16
They are great folks at Hay King. I have a small renovator and a disc harrow from them as well. Rock solid!
No modifications to the actual carrier, but I did build a wooden platform for a 200 gallon water tank that I tote around to water trees. The platform is just 2x4 and 4x4 designed so that the carrier tines slip under the platform that supports the water tank.
I typically use the carrier by itself for hauling cedar branches or long-handled tools or for moving long heavy objects like a tree trunk, etc.
You could easily build a sturdy wooden platform for it, kinda like a pallet, or perhaps weld on anything metal for your needs. I like the ability to "slip-on" and "slip-off" the water tank platform so that I can use the carrier for other tasks when not carrying water.
Good luck to whatever you do! (y)
/ Recommendation for 3-point forks #17
DIYMyWay did a good video on YouTube of building his carry-all on a frame from tractor supply. He did have his materials list on his website. His video is worth watching, youtube diymyway - Search Videos
  • Caarry-All parts List.pdf
/ Recommendation for 3-point forks #18
I bolted some old beat up truck boxes I got an auction for $5 to a pallet. Added some pipes to put shovels in vertically. It was my "fencing pallet" for years. Dropped at the work site & could keep using the tractor. Recently upgraded it to a job box.
I had a 3pt forklift for a bit. It was a pain to mount & couldn't lift more than the loader (forklift would lift, but 3pt wouldn't & I didn't want to risk it). Sold it for a few bucks more than I paid for it.
/ Recommendation for 3-point forks #19
I have a couple of Skids I made for this purpose which are basically "pallets" but instead of pallet layered construction it's just some 4x4's for the base (I usually use either 3 or 4..) with a deck lagged to the top of them. I have one of "truck bed bench seats" the previous owner of my place I can put on one of them for hauling folks in luxury and comfort (relatively speaking.. cough..) to the lower field or the back pasture. The other I put a bunch of holders for tools on for trail and woodlot work. I chain the skid to the forks when in transit.
I like the one in the video here - that's nice! Way more finely engineered than what I did.
/ Recommendation for 3-point forks #20
I recently purchased these. Haven't used them a whole lot yet but they are very well built
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2021 Chevrolet Silverado 2500 HD Royal Service Truck (A64194)
2021 Chevrolet...
2013 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2013 Caterpillar...
300# SPIN SPREADER, 3PT (A64278)
300# SPIN...
2019 Ford F-450 Flatbed Truck (A64194)
2019 Ford F-450...
