Problems at the well pump...
/ Problems at the well pump... #1
Anonymous Poster
Epic Contributor
At the rsik of getting too technical, the thingie in the pump deal with the little points doodads keeps having to be replaced. Four times in three years. Before it goes out, the points get all corroded and we can usually get away with filing them a few times before it gives up the ghost altogether. Is this a normal rate of replacment for these things?
/ Problems at the well pump... #2
Mine started sticking periodically. Seems to quit at night. I find out in the shower when the tank runs down and I have to go out with a head of shampoo and a towel and bump points with a screwdriver. (I think thingie is a pressure switch.) 3 years and not replaced. I have sprayed with wd40.
/ Problems at the well pump... #3
Cindi,
Our pressure switch (thingie) is in our basement, and hasn't been replaced. It's at least 20 years old. (My wife calls it the clicky thing.)
It must be too warm down there. You need ice and snow to preserve the points. /forums/images/graemlins/wink.gif That's my story and I'm sticking to it!
Mike
Your wife is absolutley right, clicky thingie is much more appropriate when the clicky thingie is clickying. WD 40, will pass that along to hubby. Ours is out in the open. He says ants are doing it, I just don't see how.
/ Problems at the well pump... #5
I understands completely
Pressure switches should last for years and years. Is it possible your pump is cycling too frequently? Usally the contacts are plated, so they shouldn't corrode, but maybe damp (or flood) is getting to it?
/ Problems at the well pump... #7
I can tell you from experience that ants can do the trick. They LOVE electricity. They can't wait to commit suicide on it. They have ruined many an outside AC compressor relay, and I had a friend whose entire power was shut down to his house. Turns out he had spliced his power line under ground. Thought it was all sealed up, but the ants got in there and messed it up. He ended up digging it all up and replacing the entire line, with no splices.
Ants are stupid people.
/ Problems at the well pump... #8
By the way, that "thingie" is called a "dilly-bob". You really should get your terminology straight /forums/images/graemlins/grin.gif.
Well, I was going to say doo-hickey, but that is the term I usually reserve for the thingamajig. /forums/images/graemlins/grin.gif
/ Problems at the well pump... #11
My dad says that you have to pump the holding tank (or pressure tank, is that what's called?) with air. That's why there's a Schrader valve on the tank. He says you have to open a faucet and put an air chuck on the Schrader valve and fill the tank up to the Schrader valve. I don't know if this is right, but he's only replaced points probably five times in 30 years. His well serves his house, plus three others also. I've never done this airing up procedure to my tank (been there two years now, but house is almost 30 years old), but the well will kick on everytime you use a water device.
2001 International 4000 DT 466E (A60462)
2001 International...
DRAGON 500 BBL FRAC TANK (A58214)
DRAGON 500 BBL...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
2005 John Deere 310SG Backhoe (A64047)
2005 John Deere...
2013 Volvo VN Semi (A64047)
2013 Volvo VN Semi...
2016 48ft. Fontaine Velocity 38 Ton T/A Flatbed Trailer (A61568)
2016 48ft...
