Snow pookie tractor
/ pookie tractor #1
cas1954
farm pro 2425
i 'm having an issue with my Farm pro just started last two snowfalls when plowing. The tractor seem to loose drive when the accellerator is increased.it drives when at low RPM's . The tractor has no power to drive itself HELP it's been extremely cold and the tractor is outside
/ pookie tractor #3
Does your Farm pro have a gear or hydrostatic transmission ?
/ pookie tractor #4
Is fuel gelling? Have you checked for good fuel flow from tank to inj pump?
/ pookie tractor #5
If HST what range are you using,are the fluids warm.
/ pookie tractor
the engine is runningfine just that it seems as if the clutch slips when engine is reved up
/ pookie tractor #8
Clutch iced up? Most of those tractors have a bellhousing drain in case you got water in there,.
/ pookie tractor #9
If'n the tractor slows down with the engine revs staying the same the clutch may be slipping. Might be an adjustment?? or needs a new clutch. ?
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
2005 IC Corporation PB105 School Bus (A64194)
2005 IC...
MOWER MAX SLOPE MOWER (A63276)
MOWER MAX SLOPE...
2020 JOHN DEERE 333G SKID STEER (A65053)
2020 JOHN DEERE...
2023 SolarTech Silent Advisor FD-304 Towable Solar Speed Limit Board (A64553)
2023 SolarTech...
