Snow pookie tractor
/ pookie tractor #1
cas1954
Member
farm pro 2425
i 'm having an issue with my Farm pro just started last two snowfalls when plowing. The tractor seem to loose drive when the accellerator is increased.it drives when at low RPM's . The tractor has no power to drive itself HELP it's been extremely cold and the tractor is outside
/ pookie tractor #3
Does your Farm pro have a gear or hydrostatic transmission ?
/ pookie tractor #4
Is fuel gelling? Have you checked for good fuel flow from tank to inj pump?
/ pookie tractor #5
If HST what range are you using,are the fluids warm.
/ pookie tractor
the engine is runningfine just that it seems as if the clutch slips when engine is reved up
/ pookie tractor #8
Clutch iced up? Most of those tractors have a bellhousing drain in case you got water in there,.
/ pookie tractor #9
If'n the tractor slows down with the engine revs staying the same the clutch may be slipping. Might be an adjustment?? or needs a new clutch. ?
2012 Ford Expedition SUV (A61574)
2012 Ford...
2025 Swict 60in. Bucket Skid Steer Attachment (A61572)
2025 Swict 60in...
Lilliston 4 Row Rolling Cultivator (A64119)
Lilliston 4 Row...
KUBOTA 60" QUICK ATTACH BUCKET (A64280)
KUBOTA 60" QUICK...
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59912)
2019 HYUNDAI...
