Snow pookie tractor
/ pookie tractor #1
cas1954
farm pro 2425
i 'm having an issue with my Farm pro just started last two snowfalls when plowing. The tractor seem to loose drive when the accellerator is increased.it drives when at low RPM's . The tractor has no power to drive itself HELP it's been extremely cold and the tractor is outside
/ pookie tractor #3
Does your Farm pro have a gear or hydrostatic transmission ?
/ pookie tractor #4
Is fuel gelling? Have you checked for good fuel flow from tank to inj pump?
/ pookie tractor #5
If HST what range are you using,are the fluids warm.
/ pookie tractor
the engine is runningfine just that it seems as if the clutch slips when engine is reved up
/ pookie tractor #8
Clutch iced up? Most of those tractors have a bellhousing drain in case you got water in there,.
/ pookie tractor #9
If'n the tractor slows down with the engine revs staying the same the clutch may be slipping. Might be an adjustment?? or needs a new clutch. ?
2012 MACK GU713 DUMP TRUCK (A63276)
2012 MACK GU713...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
2 Row Cultivator (A64047)
2 Row Cultivator...
HORST RSW HEADER CART (A64278)
HORST RSW HEADER...
2022 EZ-GO ELITE...
2016 Isuzu NPR 20ft Box Truck (A64556)
2016 Isuzu NPR...
