3-Point Hitch Pin For Top Link too Long
/ Pin For Top Link too Long #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
Just got a used L4740 HST but it did not come with a top link or top link pin. I had a HARD time getting the proper length pin installed. The cylinders for the bottom links are very close to the steel plates where the pin goes. Is there a "special" Kubota pin or am I just doing something wrong?
/ Pin For Top Link too Long #2
Have you tried raising the lower lift arms? I have to hydraulically raise the lower lift arms on my B7500 to be able to insert/remove the top link pin.
I was actually able to BARELY work it by lowering the lift arms. I may just need a slightly shorter pin. I found the pin I used in the tool box on the tractor and it appears to be exactly the correct length to get the lynch pin installed. Thought mabe Kubota had a special pin or method .
/ Pin For Top Link too Long #4
Can you cut/grind some off of one or both ends to make the pin shorter?
2017 Ford F-550 (A55973)
2017 Ford F-550...
2012 POLARIS SPORTSMAN 500 H.O LIMITED EDITION ATV (A60432)
2012 POLARIS...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
2022 CORMIDI C85 STAND-ON MINI DUMPER (A60429)
2022 CORMIDI C85...
207279 (A52708)
207279 (A52708)
2015 DODGE RAM 3500 4X4 CREW CAB PICKUP TRUCK (A59904)
2015 DODGE RAM...
