3-Point Hitch Pin For Top Link too Long
/ Pin For Top Link too Long #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
Just got a used L4740 HST but it did not come with a top link or top link pin. I had a HARD time getting the proper length pin installed. The cylinders for the bottom links are very close to the steel plates where the pin goes. Is there a "special" Kubota pin or am I just doing something wrong?
/ Pin For Top Link too Long #2
Have you tried raising the lower lift arms? I have to hydraulically raise the lower lift arms on my B7500 to be able to insert/remove the top link pin.
I was actually able to BARELY work it by lowering the lift arms. I may just need a slightly shorter pin. I found the pin I used in the tool box on the tractor and it appears to be exactly the correct length to get the lynch pin installed. Thought mabe Kubota had a special pin or method .
/ Pin For Top Link too Long #4
Can you cut/grind some off of one or both ends to make the pin shorter?
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
MASSEY FERGUSON 2605 TRACTOR (A62130)
MASSEY FERGUSON...
1061 (A63291)
1061 (A63291)
2015 Isuzu NPR HD Septic Pump Truck (A62613)
2015 Isuzu NPR HD...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
2006 JAYCO JAYFLIGHT 30' TYPE CAMPER (A58375)
2006 JAYCO...
