3-Point Hitch Pin For Top Link too Long
/ Pin For Top Link too Long #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
Just got a used L4740 HST but it did not come with a top link or top link pin. I had a HARD time getting the proper length pin installed. The cylinders for the bottom links are very close to the steel plates where the pin goes. Is there a "special" Kubota pin or am I just doing something wrong?
/ Pin For Top Link too Long #2
Have you tried raising the lower lift arms? I have to hydraulically raise the lower lift arms on my B7500 to be able to insert/remove the top link pin.
I was actually able to BARELY work it by lowering the lift arms. I may just need a slightly shorter pin. I found the pin I used in the tool box on the tractor and it appears to be exactly the correct length to get the lynch pin installed. Thought mabe Kubota had a special pin or method .
/ Pin For Top Link too Long #4
Can you cut/grind some off of one or both ends to make the pin shorter?
2017 Chevrolet Malibu Sedan. (A61574)
2017 Chevrolet...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
2025 JMR 72in. Hydraulic Dual Cylinder Brush Grapple Skid Steer Attachment (A61572)
2025 JMR 72in...
2012 Dodge Ram 1500 4wd (A62679)
2012 Dodge Ram...
Bobcat T66 (A60462)
Bobcat T66 (A60462)
2016 Eager Beaver 20XPT 27ft 25 Ton T/A Flatbed Equipment Trailer (A61572)
2016 Eager Beaver...
