New shop started
/ New shop started #661
Now there’s a man who enjoys his work!!!!!!
Can I ask u, how does that ceiling heater work.??
Do u wish u went bigger.??
Do u have to turn it on and come back in an hour before you start.??
I’ve seen them advertised in the Northern Tool catalog..
By chance do you know the specs or the mdl number off the top of your head.??
Thanks..
/ New shop started
Sander
My planer only does 16 ( same w jointer)
Re: modine heaters, the garage part has 2. They throw some serious heat.
Oil heat. I could leave each of the 20x10 foot bay doors open and not change the temp much.
Frankly, one would have been sufficient
I will get u btu number
/ New shop started #664
You must have built the floor for that 2nd story gorilla strong! Nice wood shop. Looks like a lot of planning went into it.
/ New shop started #665
Is it a drum or belt sander? Hard to tell with it wrapped up.
/ New shop started
Gift horse vs mouth
So the main motor control/contact was shot. I got a quote for 1300$ for the 20hp 3 ph 600v (I forget the amps) contact and also a smaller table lower 220v 1ph contact at 1700$!
That is more than the machine.
So, time to take it apart
Burnt contacts, some melted to the point the pads had fallen off
So, sweat the points off.
Grind and sand via jig
Re-silver solder 56%
Working well, now to do the 220/1ph contact
/ New shop started #668
I’ve got a 3 phase contactor I pulled from a metal cutting band saw I rebuilt. If you can use it I’d send it to you.
I replaced it with a VFD and have speed control and automated lights and coolant pump.
/ New shop started #670
What is the voltage of the system, how many HP is the motor, 3 phase or single phase? Does the starter have the old style thermal overloads? It looks like an older style IEC contactor. Should be able to find a Schneider or other brand IEC contactor that isn't $1700.00. Yeah, those contacts look beyond salvageable.
/ New shop started
Ugh, this contact was much harder. The 2 contacts across the bridge connector was “welded” shut on both sides.
I couldn’t get heat in there to separate. So I used an 1/8 mill to cut thought the back of the contacts so I could slide them out. Of course this ruins the contacts on the tabs so 2 new contacts cut with shoulder to solder in and back together. Continuity indicates function so I will test later
/ New shop started
Cammo, here is order minus shipping and tax 1500$ plus about 100$ tax and 80$ ship
3 phase 20 hp, 80 amp circuit with a 30 hp rotary converter.
They were “beyond” so I made new.
Main motor is good, now to reinstall table controls
/ New shop started #673
Chances are that you have checked, but have you looked at places like Radwell? They buy a lot of NOS industrial surplus controls and resell them at a substantial savings. I know our company has sold them many pallet loads of controls, all new in the box, they have just been sitting on the shelf for 10-15 years, collecting dust.
/ New shop started
I had a brief amount of energy today.
Tuned up the swing saw mill
Cut some 1/16 x6” pine to true it up and then loaded up some oak to cut
And now, I’m done for day (health and age are fighting me)
/ New shop started
Typically I use the forks on the Deere but I am now using the ex more and more for tasks like this. More precise and easier on machine
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
2011 FORD F-750 CHEMICAL TRANSPORT TRUCK (A65643)
2011 FORD F-750...
Unused 2023 Maybridge B7D 6ft. Chain Harrow Tractor Attachment (A66734)
Unused 2023...
CAT 953 4-in-1 Bucket (A68134)
CAT 953 4-in-1...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2012 MERTZ ART. ARM MANIFOLD TRAILER (A67714)
2012 MERTZ ART...
