New shop started
/ New shop started
Grabbed some more wood for the Peterson sawmill, pine and oak
Little deere never ceases to amaze me.
/ New shop started
Going to be restricted from lifting For the next six weeks so I had to go grab this from the scrap yard. I need a little cordwood saw to restore to put on the back of the Jeep
Looks like blade was maintained by KWS, Doesn’t appear that they’re still in business
Can’t make out the blade sticker
Boston gear gearbox drive via triple belt and dealer sticker
/ New shop started #344
Cool. How long are those forks? 5 feet? Or?
Nice that you have decent visibility with the tailgate removed.
/ New shop started
Didn’t measure
I think u are right, about 5
I will likely make a carry-all/deck that i will use the forks to pick.
/ New shop started #346
Consider building a see through slatted backrest for it. Maybe vertical flat bar looking through the “edge”.
Something like this
/ New shop started
Good idea
It may just be a wood build for now
This is light duty anyhow
/ New shop started #348
Maybe an angle iron frame and expanded metal so you can still see through?
/ New shop started
I do have some bed frame angle that would work
Likely I won稚 use it as fork machine
A carry deck is more the goal. That would be more useful.
I will be out of commission for 6wks so for now it is all just a dream
Keep the ideas coming
/ New shop started #350
hope you recover fully and all goes well.
I've never seen a car/truck with a three point on the back.
/ New shop started #351
The same well wishes.! Gotta try out all those good ideas you will be coming up with while out of commission.
/ New shop started
Thx guys
Daugen
I think there was a setup for scouts and obviously jeep.
I always liked Farm Jeeps and there is plenty of research online.
The CJ5 setup is (nearly to the inch) the same size as neighbor rtv1100.
It is funny to see the next to each other. Nearly 60 years between the UTVs.
/ New shop started #353
Love that 3pt on the rear of that jeep. Any chance of PTO to run a mower?
Hope your procedure goes smoothly.
/ New shop started
It has rear pto
I have a gearbox for front pto also, just not installed yet
Before I add it, I have to make a decision about a tranny swap. Have another transmission with overdrive/splitter. In order to get the PTOs to work on this it requires an adapter and some changing around of the driveshaft lengths. I haven’t made a decision about overdrive or not so I’m holding off on adding the front PTO at this point.
/ New shop started
So frustrating
A cat on my lap technically pins me
They seem to know this...
/ New shop started
A nice day to mill
Now I have that 杜uch needed oak for a 菟roject that doesn稚 exist(yet)
/ New shop started #359
A nice day to mill
Now I have that �uch needed oak for a �roject that doesn稚 exist(yet)
Are you sending that nice oak to a kiln to dry? Or just air drying it. I have some ash and 2 nice white pine set aside to go to a sawmill. Last time I air dried white pine and cedar in an enclosed pole barn. Jon
/ New shop started #360
That's a nice piece of wood. will it warp while drying? Will you put more support pieces in between your nice beams?
Landhonor Quick Attach Rock Bucket (A66285)
Landhonor Quick...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
2017 Autocar Xpeditor T/A Heil V-161 28Yd Front Loader Garbage Truck (A61573)
2017 Autocar...
2017 FREIGHTLINER CASCADIA 6X4 TA SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
