New shop started
/ New shop started
Sounds like you dodged a bullet on that particular boat!
That’s sad in regards to the maintenance. I think the boat is a perfect combination of cruising and fishing. It checked off all my must-have’s including cabin where the admiral can relax, rebirth, Galli, bathroom with shower, quarter birth for additional sleeping room, cockpit for fishing, diesel power and stability when sloppy.
I was attracted to the Downeast style type of boat but realized to get everything that I wanted I was going to have to step into something closer to 35’+. This is a very “big” boat for 31 feet
/ New shop started
^ I hear u
Post Christmas shopping done
Bird seed and 300lb of scrap steel (one 2”x2”x2’ square and 4 3.5”x2’ round)
Also went out for some firewood
Quadractor doing what it does best, I should tear it down
and refresh it again
/ New shop started #284
Cool!
Any plans for the round and square stock?
How much a pound are you paying for scrap?
Merry Christmas!
/ New shop started
No plans just hitting up the scrapyard for “treasures”
Price was close to 100$ so around .30?
/ New shop started #286
Ahhh, treasure.
Our CNC lathe at work has a 4" thru spindle, but I have a Royal 16C collet setup on it and it only accepts up to 1.625" stock. I have to put the real heavy chuck on for bigger stock like this. It is not a job I enjoy (exchanging chuck for collet setup)....
/ New shop started #287
That's a neat buggy. Is there a build thread anywhere on it? Assuming hydraulically driven?
/ New shop started
No build thread as they were factory produced in late 70’s
4wd, 4 wheel steer, weight is 500 lbs but can pull a lot
All belt driven in a rather complex Tho robust fashion. (these are the same belts that have been on this machine for the past 10 years since I originally rebuilt and then sold the machine and then got it back after somebody didn’t take care of it as well as I would’ve liked)
Read here for more info
The Incredible Quadractor From Traction, Inc - Modern Homesteading - MOTHER EARTH NEWS
/ New shop started #290
Interesting....never seen them before, and I've been involved with ATV's since the early '70's.
/ New shop started #291
I miss the old days when scrap metal was pretty much given away. Now too many are wise to the value because too many are wise enough to repurpose. Oh well.
/ New shop started #292
Salvage yards are paying only about $.03-.05/lb for steel. So selling it to you at .30 is ten fold markup.
Price of titanium 6Al4V varies from $27 to $35 per pound depending on what/how much you buy.
Scrap titanium (chips and shavings) is not worth much at all. Not sure why.
/ New shop started
I understand the markup I sell scrap also.
I don’t fault them, still a good price, pricing mild steel at 3.5”x24” I would have paid close to 100$ without shipping (per piece)
All together it would have been 480$ plus shipping on 300#
/ New shop started
Time to start installing the 3 point hitch subframe
Another old pic for the quadractor fans
/ New shop started #295
Aluminum 6061 is running about $2.15 a pound and we are getting $.15 a pound on chips right now. Steel chips are worth zero - they will take them if you deliver them but they will not pickup. I won't even run steel jobs now due to waste.
/ New shop started
Started back on this old 22LR 1919 conversion project. I had some pierced primers. Before shortening the spring a bit I considered whether the 22 cartridge was really seated into the 30 caliber “dummy” round. I seated them gently with a press to ensure they sat against the shoulder. There was some “stickiness” in the last 1/16” that makes it hard to seat with thumb pressure. No piercing. I will have to take the dummy rounds and make sure that they are fully cleaned up any cosmoline that is possibly causing the interference.
/ New shop started
It is a hoot!
A lot cheaper to feed than 308 (mine is 308 not 30-06)
/ New shop started #300
A friend of mine did similar but mounted them to the rafters, instead of conduit clamps he drilled a 1/2" hole in one side and a smaller hole in the other and just used a single screw into the rafter, I think he has another a few boards down for the other end of the pole to take the strain off. Once I get my shop built, I'm definitely doing something either on a wall or ceiling to hold poles... but I need to pare my collection down...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
Harrell 6710 (A64126)
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2002 Built Rite Trailer (A66285)
2002 Built Rite...
New/Unused ATS Plasma Cutter (A65583)
New/Unused ATS...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
