New shop started
/ New shop started
Salt water, near Long Island sound/block island sound
/ New shop started
Moved the power hammer out to farmer porch/blacksmith area
/ New shop started #243
Blacksmith area??? Cool - we need more photos. I would love to set something like that up at some point.
/ New shop started
So removed the bestop and put on the hard top
Also dug out an LED light that neighbor was tossing. Temporarily mounted for fit. Now to make up some brackets and switch
Let me know if u need the besttop
/ New shop started #246
My buddy says to mount it just above your bumper for better lighting. Overhead creates glare.
/ New shop started
Thank u for advice
This is the farm plow in the winter, so no bumper mount
It also serves to camouflage a few blemishes on my 20 foot paint job
Ps u can see the 3 point hitch system being prepped on the die cart in first pic
/ New shop started
2 days off
Traded the 3/4 for 1 ton
Wife is happier w/o lift and 37 but I hate the stance. So 3 Front/1 rear level kit going in. Also got to undercoat the ram/jeep and crane truck for winter
/ New shop started #249
I'm one of the weird ones that loves the smell of Fluid Film ...
/ New shop started
Directions= misleading, inaccurate
Kit mostly complete= again, should not be my problem
All told, about 3 hrs, could do it again in about 1/2 that knowing what I know now.
Before:
39 front/43 rear
Apart:
Final:
43/43
Got to practice my endoscopic skills grabbing a dropped spacer in the frame
/ New shop started
5$ scrapyard stand adapted to new blade grinder
/ New shop started #252
That, back there was what you call a fork lift!
I'm looking for some kind of belt sander, just not that big. Don't have the room. Be carefull. A friend has one where the belt broke and slapped him good.
/ New shop started
Yes, tried it out today
Definitely need a face shield
Goggles were not enough
Forklift is a Clark ranger 6000lb capacity
Fwd or rwd or 4wd
Articulated and does fine on lawn and in woods
/ New shop started
Got the ram/crane truck and cj5 undercoated today
Fluid film was a bit thick at 60 deg, warmed up to 90-100 to be able to pour in spray containers
1 gallon gave good coverage for all 3 vehicles (2/3 went on crane)
/ New shop started #255
Not articulated. Not that I can see. Never seen such a thing except wheel loaders being used as a fork lift. Kind of not the ideal machine anyway given their instability when crooked.
/ New shop started
I am probably using the wrong terminology. Rear wheels/axle steers and entire center section rotates around at central portion so for wheels are always in contact with the ground
Four tires are always in touching the ground as the entire machine pivots around the center of the machine
Articulation spec
/ New shop started #258
You are absolutey correct on your terminology. Trouble is, I want one.
/ New shop started #259
You are absolutey correct on your terminology. Trouble is, I want one. What's in it for power?
It's like my articulated loader. Hardly leaves a mark anytime of year.
/ New shop started
There were some rather reasonable rust studies that were done by several people on the inter-web. It may have been in garage journal?
For a lubricant I prefer boshield
For an undercoating on a vehicle and rust prevention, fluid film seems to have one of the best overall protective abilities. (Of course it Has to be resprayed from time to time. (yearly For me in New England salt))
I will try googling them for you later
Drag Tank, Fill Rite 15GPM PUMP  (A62679)
Drag Tank, Fill...
2023 Case TV380 (A62177)
2023 Case TV380...
Kubota B21 TLB (A60462)
Kubota B21 TLB...
2021 Kubota KX080-4 (A64126)
2021 Kubota...
2024 JCB 35Z (A60462)
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
