New PT-180 owner
/ New PT-180 owner
Good news!!! The 180 is in fantastic working order now!!! I used it for a couple hours this evening. And even found some concrete. Evidently next to my shed there was a short sidewalk with roughly 4'x4' sections that I was able to pick up and move outta the way. The downside. I have a leak in the left front. I couldn't find a nail or anything and now I'm debating taking it to a tire shop or just pumping some slime in it and calling it a day...
/ New PT-180 owner #102
Gempler's Ultraseal tire products - great stuff. I went 4 or more years without adding air. Impressive stuff but not cheap. Worth every penny in my opinion. I was getting flats constantly prior to using it. Now I have it in my ATV and tractor.
ultraseal — Gempler's
Ken
/ New PT-180 owner #104
Ultraseal is so much better than slime...I have it in 32 tires on 6 machines and no flats/air in a few years.
If you look into it, and want to go forward, pm me about borrowing the pump. I'd consider mailing mine to any pt people.
/ New PT-180 owner #105
Something else i found with tires, was the valve stem being pulled out. There were two in each rim, inside and outside, I got metal ones to replace the rubber ones on the outside and metal plugs for inside.
/ New PT-180 owner #106
Yes, the inner stem was a real headache. It can be replaced with either a plug or just flip the existing rubber stem around so the cap and stem are inside. Obviously not if it's already damaged.
I've also welded chunks of pipe around the outer stem. No more ripped off.
/ New PT-180 owner #107
So I thought I'd be smart and I tube my tires if they go flat. Well, I tubed one of them, and put the stem on the INSIDE HOLE! :laughing:
I left it that way, but now I can't remember which one it is. Next time I have a problem, I'll MARK THE CORRECT SIDE, pull the tire off the rim, weld the hole shut, and tube it right-side-out! :laughing:
/ New PT-180 owner
That's pretty funny, oh I found a group on facebook for power trac owners if anyone is interested.
/ New PT-180 owner #109
On that subject, how many of you to your own tire removal? I found out a trick that works really well to get the tire off the rim....
take it to a tire shop. :D
But seriously, I took it in once and they only charged me $10 to remove the tire and install the tube I supplied. Now, they no longer will do that due to liability. So, I do it myself at home with some harbor freight pry bars. I'm thinking of getting 1 of these for $40 at Harbor Freight. With a 20% off coupon it would only be $32.
/ New PT-180 owner #110
I have only done it with pry bars, and not for a long time. And no, I don稚 miss it. It was a bad combination of bad roads, bad Firestone tires that at one point gave us seventeen flats in six weeks. We got really good at tire changes and repair. Practice makes perfect and all that. We went to Michelin tubeless and had one flat in eighteen months on the same roads. Ask me which brand I have bought for the rest of my life...
That tire replacement stand takes a lot of stress. So, you would probably need to bolt it down, which means having a permanent spot for it. That alone would keep me from doing it. You may have more room in your shop than I do.
As always, YMMV...
All the best,
Peter
/ New PT-180 owner #111
As always, YMMV...
All the best,
Peter
I have room. Will have more by fall, hopefully.
/ New PT-180 owner #112
My brother who lives next door has a commercial tire changer, but I have so much trouble getting these tires to take air and set the bead that I still take it to a tire shop. Anybody got any good tricks for that?
/ New PT-180 owner #113
Personally, I found that a little bit of bead sealant/lubricant makes a huge difference. I used to use Murphys oil soap. After that, it is figuring out how to jiggle the sidewall to get the bead to catch on the rim. I know pros who use a cheetah but it is pricey...
But I prefer your solution. :)
All the best, Peter
/ New PT-180 owner
I have used a cheetah before. I worked at a rent to own company that did wheels and tires and we used the cheetah to launch lug nuts through the bathroom door when a guy was in there. Typically if I needed to seat a bead I would stand the wheel up with the unseated portion facing up and lower the fingerlift (with vehicle on it) down to squeeze the tire and push the sidewalls out. Then with the pressure on the wheel you add air and the bead would usually seat. It was faster than the cheetah. However, any type of lube will work to help the bead seat. We only worked with low pro tires so sometimes the lube wasn't enough. (Think 24"+ wheel with a 20 sidewall)
/ New PT-180 owner #117
I found it harder to do the small tires/wheels then car size and up. At a tractor engine show I bough a antique machine like the one Moss shown and it works great. To save space I bolted to a slab of concrete and use the forklift attachment to bring it inside when I need it.
/ New PT-180 owner #118
:thumbsup::thumbsup::applause:
/ New PT-180 owner #119
Dang, I'd never even heard of a cheetah before. Looked at it online. I see a real Cheetah costs $400, but I see knock-offs on EBay for mid 50's. Are they any good or an accident waiting to happen. Like M5040 says, I never have trouble with car or truck tires that a ratchet strap won't fix, but these little tractor tires give me fits. My buddies growing up used to have an inflatable tube that would fit around the tire to compress the bead and that always worked pretty well, but I haven't seen one of those in years.
/ New PT-180 owner #120
I would go for whatever works for you. Ratchet strap, jiggling, cheetah, rubber bead seaters, pneumatic bead seaters, they all kinda work. Anytime that I see a dozen solutions for a problem, I think that all of the solutions are about as effective. The only one that I wouldn’t recommend is butane/propane. (YouTube it. Definite Darwin Award material in my opinion, but YMMV...)
All the best,
Peter
