New Kioti Please help! Many issues
/ New Kioti Please help! Many issues #61
Hi. We are in upper northeast corner of TN.
We requested the Kioti 3rd function valve and it was supposed to be a full install kit.
(423) 323-4902
Did you try Eaton and Son in Blountville TN? Website says in business since the mid 80's.
I am in Hancock Co and we lost our dealer a couple of years ago. I have not needed one recently & have bought parts online.
/ New Kioti Please help! Many issues #62
Thank you for your input, but all that is pretty much Greek to us. We did not install the valve ourselves as we requested that the 3rd function be put on the tractor we had just bought before it was delivered.
Understand about possibility of blockage or debris. Will check it out.
This gets extremely hot, wouldn't want to hold onto it for long.View attachment 5207983
This is the KIOTI 3rd Function Kit for the CK2510 / CX2510 tractors. You had mentioned in your previous post it was "under the right step". This is the loader bracket mounted 3rd Function Valve.
Obviously, this should get warm, but not hot. As previously mentioned, make sure the P and T ports are plumbed properly. P port on the 3rd Function Valve from the Joystick Valve Power Beyond, T port back to the the port the original Power Beyond pipe was removed from. If plumbed properly, 2 other possibilities; the 3rd Function Valve is constantly powered, from either faulty switches or improper harness installation, or if the tractor has Rear Remotes, the lever is not in neutral.
Hope this helps
/ New Kioti Please help! Many issues #63
Hope this helps
Good response.
Hard to troubleshoot hydraulic/electrical installations when not on site, especially with a new owner operator.
/ New Kioti Please help! Many issues #65
Here is a link to a Summit install of a 3rd function on a CX, it will give you something to compare your setup to.
To the OP are you aware of how to operate your 3rd function? You should have two seperate switchs each switch will activate one solenoid, one to (open) while held, the other to (close) while held. The solinoids should not be energized unless you are holding a switch.
1996 FRUEHAUF 45' SLIDING AXLE FLATBED TRAILER (A59911)
1996 FRUEHAUF 45'...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
JOHN DEERE 6120M TRACTOR (A64280)
JOHN DEERE 6120M...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
2011 GREAT DANE 7211TZ 53FT T/A REFRIGERATED TRAILER (A59912)
2011 GREAT DANE...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
