New 2025 Ram 1500 with hurricane engine.
   / New 2025 Ram 1500 with hurricane engine. #42
A "1/2 ton", v8, stick shift, wing windows, rubber floor mat, manual windows etc!
Honestly, does it matter if it's I-6 or a V-8, or a V6, I just know the 5.7L Hemi is a fuel efficiency, good motor, with good longevity; IF you avoid unnecessary idling. My worry, is I-6TT, what is its flaws? We know the Hemi's. So, maybe it's idling that will kill them, maybe it's going to want new air filters every 5000 miles, maybe it's some kinda computer controlled boost issue, but every motor has its faults. It's just nice to have one that you know it's issues.
With that, I do hope Ram put together a quality machine. Some of those Wagonners should be well over 150k now, if it's been out for 2 or 3 years, so, maybe the faults are I'D. Online, the discussion appears to be turbo issues, cooling failures, and fuel system. Not sure those occur at high rates,
   / New 2025 Ram 1500 with hurricane engine. #43
Fuel efficiency? Yeah right 😂
My 5.7L returns a very best of 17.5 mpg in the summer with optimal driving, and 15 mpg in the winter.
The 5.7L reliability is good, not great.
My particular year has a notorious bad habit of snapping exhaust manifold studs, along with coil failures, and the dreaded destroyed engine if you wipe out some cam lobes. Some feel it’s excessive idling, but no one knows for sure.
I do like my 5.7, but I’m realistic about its pros/cons. The engine issues have cropped up during the many years of production.. not on the first year or two when it was first produced.
   / New 2025 Ram 1500 with hurricane engine. #44
My particular year has a notorious bad habit of snapping exhaust manifold studs, along with coil failures, and the dreaded destroyed engine if you wipe out some cam loves.
I do like my 5.7, but I’m realistic about it’s pros/cons, which issues have cropped up during the many years of production.. not on the first year or two when it was first produced.
Cam lobes and lifters is what I meant by excessive idle.
2019 Ram Classic 5.7, crew,, 4x4, 19 to at times 20 mpg. Even if we go to 24 mpg for the TT, that's $3,157 per year vs $2499 per year in fuel, driving 20,000/year. We are talking a fuel savings of less than $750/year.
No, I'm not saying the hemi was "bullet proof", but none of them are; we just know it's limitations, and the Hurricane will have its own, different, limitations.
   / New 2025 Ram 1500 with hurricane engine. #45
Lotta “stuff” on it.
You wouldn’t know by the shape, there’s a long skinny inline-6 under there 😂
A bit surprised they’re using an aluminum block
Made in their Mexican plant.
   / New 2025 Ram 1500 with hurricane engine. #46
Good thing the displacement is small so they can pile 500lbs of junk on it.
Man this crap has to end.
   / New 2025 Ram 1500 with hurricane engine. #47
Like every Ford engine I ever owned.
   / New 2025 Ram 1500 with hurricane engine. #48
re twin turbos - my recollection is that this engine has one turbo per 3 cylinders, kinda like a twin-turbo v8 where there's one turbo per bank -- it's not a sequential turbo setup.
It's twice as many turbos, but they're smaller and lighter, less inertia. I wouldn't worry about the "twin turbo" aspect of the engine.
I would, however, be concerned about buy a first- (or possibly even second-) year of an engine in production, however - even though they've likely been running it in mules for at least a few years, there's likely been tweaking here and there and it's not a settled configuration till it's sold in volume; it's a rare engine that doesn't have an iffy start.
   / New 2025 Ram 1500 with hurricane engine. #49
Really tho, other than the pulleys and belts on front giving it away you'd be hard pressed to tell it's actually an engine, ridiculous, I wouldn't want to have to work on it for anything other than an oil change. Always blows my mind when you look at an old engine, take an old 225 slant 6, and compare it to that engineering nightmare:
   / New 2025 Ram 1500 with hurricane engine. #50
That’s a “performance” 2 barrel version😁. My ‘68 had a 1 barrel carb.
All this crap they put on isn’t because they want to. It’s all to meet ever tightening government regulations
   / New 2025 Ram 1500 with hurricane engine. #51
I wish we would have got the Hemi 6-Pack in the US. Chrysler Australia made good use of it after the Straight six project to replace the Slant-6 was stopped in the US.
   / New 2025 Ram 1500 with hurricane engine. #52
It has to be better than the Chevy baby duramax, with what, a rear of engine timing chain and water pump, or something rediccoulus like that, that involves an engine pull between 100-150k miles.
   / New 2025 Ram 1500 with hurricane engine. #53
I want one of those, but that is truly a crazy arrangement.
   / New 2025 Ram 1500 with hurricane engine. #54
My ole Valiant had the one bbl carb also and a seized heat riser valve, (least it didn't rattle) You could always tell an experienced Dodge driver, he had at least one spare ballast resistor in the glove box, as well, you had to turn the radio off if they were forecasting rain.
Which never ceases to amaze me, the more crap they add to an engine, the lower the mileage yet it's better for the environment seems awfully counter intuitive to me. Same as diesels having to sit doing absolutely nothing for who knows how long burning fuel to regen all the while the mileage drops.
   / New 2025 Ram 1500 with hurricane engine. #55
Crazy. They just sit around and make more regulations.
When will they understand the suffering they cause.
   / New 2025 Ram 1500 with hurricane engine. #56
That sounds like a nightmare. Almost as bad as the Tacoma (I think it was ) with the starter buried under the intake manifold.
   / New 2025 Ram 1500 with hurricane engine. #58
It's the oil pump drive belt. They replace it by removing the transmission to get into the back of the engine, which stays in place. The 2022 and later have a longer service interval- 200k miles. The belt's the same as the earlier one with 150k mile service intervals.
It's like $350-400 in parts but a lot of labor.
   / New 2025 Ram 1500 with hurricane engine. #59
What about the BMW with the starter under the intake manifold that was one piece with the head.
   / New 2025 Ram 1500 with hurricane engine. #60
Here's the thing. The old slant-6's made about 0.6 hp/cid, or 145 hp out of the 225 cid variant. The Hurricane you're all griping about makes 2.2 to 2.8 hp/cid, literally 4x more power.
With that sort of difference, to me anyway, looks and longevity become almost completely irrelevant... not that the old ones are known for going longer miles anyway.
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2022 FORD TRANSIT 250 CARGO VAN (A59905)
2022 FORD TRANSIT...
2022 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2022 KOMATSU...
