Mixing container for 2-stroke fuel
/ Mixing container for 2-stroke fuel #1
quicksandfarmer
Elite Member
Coastal Rhode Island
Jinma 354, purchased 2007
I decided last week that I've lived long enough without a dedicated container for mixing oil and gas for 2-stroke engines. I really just needs something for measuring gas, I buy oil in calibrated squeeze bottles. Right now I have a 1-gallon plastic gas can that I've drawn lines on with a Sharpie, it works but just barely. I typically mix a quart to a half gallon of fuel at a time, I don't like to mix more than I'm going to use in a fairly short time.
I'd prefer to have a mixing container with a cover so I don't fill the garage with gas fumes.
What does everyone use?
Thanks.
/ Mixing container for 2-stroke fuel #2
works fabulous and allows different ratios and different gallon amounts per ratio. Have it 15 years still works great
Thanks. Something like this is pretty much what I had in mind. I've gotten wary of buying things like this on Amazon because you never know what the quality is going to be like. I don't need any more plastic junk.
/ Mixing container for 2-stroke fuel #7
Thanks.
A one gallon gas can and a small measuring cup for the oil, similar to this...
I also use one that's larger for my pool chemicals.
/ Mixing container for 2-stroke fuel #8
its a plastic bottle, not a lot they can screw up here.
/ Mixing container for 2-stroke fuel #10
You'd be surprised. Lid that doesn't fit or leaks. Plastic that cracks. Inaccurate gradations.
well its been fine, its stored inside and has no damage or overall degradation, at 9 dollars or the cost of a quarter pounder now, I say take the risk
/ Mixing container for 2-stroke fuel #13
I have a two gallon gas container before all the silly gas can rules. I buy the small Stihl containers for 2 gallons.
I kept a few Stihl bottles and buy 2-stroke oil by the quart, then refill the bottles, much cheaper.
Now that I have a 40V Ryobi chainsaw for trimming and de-limbing down trees, I;ll probably never use up this last quart.
/ Mixing container for 2-stroke fuel #14
I use the cans that the premixed fuel came in, made of metal with a tight fitting lid. Pour in the right amount of oil, then fill it with gas and maybe shake it a little. And, it is already labeled as premixed two stroke fuel.
/ Mixing container for 2-stroke fuel #15
I don't go through a lot, so I use a half gallon plastic whiskey jug. Got a small beaker from AS&S that's marked at 1oz, and a plastic kitchen measure. Make 40 oz of 40:1, easy to shake and mix, easy to see how much is left, and easy to tell it from the straight gas. And easy to fill small tanks.
/ Mixing container for 2-stroke fuel #16
Ditto! So easy even I can do it right every time.
OH! And I try to NOT empty the mix fuel can down to the last drop. When the new OIL is poured in, the old fuel easily sloshes into a good mix for when the fresh gasoline is pumped in.
Sometimes I stop mid fill and give the can a bit of a slosh as well. I trust the turbulence during the fill does a great mix job. I've been doing it this way for more than 65 years without troubles (except I used to need to measure out the oil from a quart can or bottle). These "pre-measure" 50:1 bottles are the cat's pajamas!
/ Mixing container for 2-stroke fuel #17
Once I went to canned fuel, my small gas can I used for pre mix gets the canned fuel put in it as it's easier to fill saws and the like from it rather than the clunky gallon metal cans the canned fuel comes in. Canned fuel has a much longer life than pre mixed corn squeezed gas.
/ Mixing container for 2-stroke fuel #18
50 to 1 works with any thing. 3 oz or so to one gallon. I don't have different mixes for the two stroke stuff. Even if they call for 30 or so. Never had an issue burning any thing up. The two strokes fail, always for other reasons.
/ Mixing container for 2-stroke fuel #19
I actually use a tablespoon if I have a bulk bottle of two stroke oil. I printed out a chart for how many tablespoons per ounce. I often buy the little bottles of oil that you dump in a gallon of gas. No mixing involved, just dump it in a gas can, fill and shake a little. Just dump it in a full tank of fuel in your car or truck if it gets a little old.
/ Mixing container for 2-stroke fuel #20
I run the old stuff through the four stroke lawn mowers. A little smoky... so what. :)
2022 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2022 KOMATSU...
BUNDLE OF 2"X8"-13'-19'L METAL FRAME WALL STUDS (A60432)
BUNDLE OF...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
2001 Ford F-150 4x4 Pickup Truck (A59230)
2001 Ford F-150...
2023 FORD F-650 SUPER DUTY CAB AND CHASSIS TRUCK (A59823)
2023 FORD F-650...
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
