Man killed while felling trees
/ Man killed while felling trees #1
PhilNH5
Platinum Member
SE NH
Kubota B3000HSDCC
Here is a link to theNashua NH Telegraph story of a man killed while cutting down trees.
Not a lot of details but two stand out. A) He was working alone and B) Unfortunately his young daughter discovered him.
Be careful out there.
Phil
/ Man killed while felling trees #2
What a sad but probably very common story /forums/images/graemlins/frown.gif. I am sure that most of the members like myself here in this forum are use to cutting down trees like this but it never hurts to be reminded to work smart and safe. Thanks for the reminder to be careful out there.
/ Man killed while felling trees #3
SAD /forums/images/graemlins/frown.gif but i think more folks should use the WHAT IF PRINCIPAL. what happens if? and what happens if this happens ? too many times guys get to comfortable doing a task that they have done before, BUT every task is slightly different.
/ Man killed while felling trees #4
Man...I've cut some trees that size and larger and almost always work alone...
Wonder what actually happened...
One thing about those trees...you just never know for sure which way they will fall until after they hit the ground. You think you do, but things happen.
Such a sad thing. Hope the rest of us have better luck.
These days when I am uncertain I tend to use chains tied to other trees to ensure the tree I am cutting will fall about where I think it is going to.
Guess one never knows though. I also park my tractor pretty far away, so if all goes wrong I only have to worry about me...and hopefully can move away in the opposite direction to which the tree actually falls.
My heart goes out to that little girl who lost her father...
/ Man killed while felling trees #5
Can't speak for other parts of the country, but in New England, the wind can shift quickly and when you are cutting trees, that can get you in trouble quickly. I was cutting trees for the house clearing with a new saw (had already worn out two McCullough saws and finally decided to purchase a Husqvarna chain saw) when the wind shifted and the tree started to go the other (wrong) direction.... I just dropped the saw and started running.... good thing, because that tree came down on the saw and would have taken me out with it. The saw can be replace, but I can't. The saw was fixed inexpensively, but if the tree had hit me, I am sure that I couldn't be put back together any more so than Humpty Dumpty...
Every time that I hear about one of these type accidents, I wonder how much instruction and experience the person had in cutting wood. When I purchased my saw, the person that sold it to me, suggested that if I was going to cut trees, that I start with the very smallest trees and work my way up to the larger ones when I felt that I had enough experience. More than once, a tree would get hung up in the branches of another tree. I never cut trees unless there was someone else there and we always had a spare chain saw and tow chains if needed. I always wore chaps, hard hat with shield, ear protection, long sleeves and gloves. Many thought that this was extreme, but I had seen what happened to a person when the chain broke and hit him in the face.... that was back in 1962 and that person lived with the scars, both physical and mental his whole life. I didn't want to wind up like that. It is when you feel comfortable and let down your guard, that mishaps occure...
Here is theUnion Leaders version
You may have to register to read it.
Not much more info. The neighbor thinks the victim tried to free a stuck chainsaw with an axe.
The victim was recently laid off and was keeping himself busy.
Very sad.
Phil
/ Man killed while felling trees #7
I have one comment to make about this story:
No mention was made that anyone performed basic life support on this man. Apparently, he was not breathing when rescue personnel showed up. Had someone known CPR, the man may have been able to live. CPR may have been difficult under the circumstances, but I can't judge that from the story.
My point: Everyone should take CPR classes. It only takes a little time out of one's day, and could save the life of someone you love, or at least someone that someone else loves. John
/ Man killed while felling trees #8
Airway management and CPR would be difficult with the 18 inch "tree trunk that fell across his throat and chest." Also, the bystanders "Hamelin and Michaud's wife, Patricia, tried to lift the tree, but it was too heavy." You have effectively 4-6 minutes after the tree falling to remove the trunk and establish circulation. Any longer time, and Reggie is no longer the Reggie everybody knew and loved. If he didn't have a pulse after the tree was removed, I'm sure that he was long past the 6 minute mark.
While I am a supporter of prehospital care and BCLS (airway and CPR training), there are times where nothing can be done.
/ Man killed while felling trees #9
The article said that the tree was across his chest when the rescuers arrived and it took 4 of them to get it off of him. CPR is definitely a good thing to know but in this case it apparently could not have been used.
/ Man killed while felling trees #10
A neighbour knowing how to run or having a working chainsaw would have been needed for CPR to help.
I too work alone felling trees on occasion, this weekend I felled a 36" dia pine that has been dropping huge limbs and was rotten in the core. I didn't try that alone! I now use wedges, always. Many people tease because wedges aren't popular here but they save dangerous frigging when trees go the wrong way and hang up.
Having a tractor helps too as you don't tend to try and chop a chainsaw free. I have a spare saw available if the first got stuck but the wedges pretty much ended that.
Some workers here can't carry several saws so they carry a spare bar and chain to swap out.
Ken
1969 VOLKSWAGEN BUG (A59905)
1969 VOLKSWAGEN...
2025 SDLanch SDLL30 Mini Stand-On Track Loader Skid Steer (A59228)
2025 SDLanch...
2022 CATERPILLAR 299D3 SKID STEER (A62129)
2022 CATERPILLAR...
2016 DRAGON SAND CONVEYOR (A58216)
2016 DRAGON SAND...
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
