let's discuss the best way to mow a field...
   / let's discuss the best way to mow a field... #11
Rocket science is easy!
...It's rocket engineering that is the difficult part.
   / let's discuss the best way to mow a field... #12
Its mowing and not rocket science . mow a round on each end lay off a land and start . work left to right / right to left it really doesn't matter . just start on longest side
X2. .
   / let's discuss the best way to mow a field... #13
80%? Eh. It's "A Number" I suppose. Good as any! :confused3:
I'd guess in reality it's wide ranging +15% (65%-95%) depending on the size of the field and its geometry.
Here are some estimated efficiency factors for various implements from http://caes2.caes.uga.edu/engineering/handbook/documents/capacity.pdf. You could achieve 100% efficiency if you were mowing a single swath exactly the width of your mower around the circumference of a field under center-pivot irrigation. But given my age, I might have to allow for a bathroom break.:)
Steve
   / let's discuss the best way to mow a field... #14
IMHO spitting a field more especially a large field into 2 or more lands just creates ""more corners which requires more time"". Start at outside go round & round then when you get to the middle then mow the corners & your done.
   / let's discuss the best way to mow a field... #15
When I was mowing my 3 1/2 acre yard, I though about the same thing and my Navy background kicked in.
In a search and rescue scenario, you want to cover the search area as quickly as possible and leave no portion of the area un-searched.
When you have a large but defined area, the recommended search pattern is called "Parallel Search". So that's the pattern I used when mowing.
The problem is you need to be able to do a 180 degree turn in the width of your mower.
   / let's discuss the best way to mow a field... #16
If the field is round Thats an option. Every time I see someone mowing in circles when they are done it looks worse than stump whooped chittlens.
   / let's discuss the best way to mow a field... #17
..... Every time I see someone mowing in circles when they are done it looks worse than stump whooped chittlens.
That's a new one for me.:) Any photos of what they look like?;)
Steve
   / let's discuss the best way to mow a field... #18
Steve
if you know what chittlns are and what they contain its not hard to imagine that everything will be covered in SHYT
   / let's discuss the best way to mow a field... #19
I use NASCAR method ..........go fast and turn left!
   / let's discuss the best way to mow a field... #20
You know - I see/hear a lot of good ideas on how to mow. Except I sure don't want any "stump whooped chitlins" round here. I don't give a D-A-M-N how good they are. I got a good idea what it looks like also - I had an occasion to dispatch a raccoon with a big stick. It wasn't pretty and it smelled to high heaven.
Amada M-3060 Mechanical Metal Shear (Japan) (A59213)
Amada M-3060...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
THREE POINT ATTACHMENT (A58214)
THREE POINT...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
Unverferth 9250 Auger Wagon (A59814)
Unverferth 9250...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
