let's discuss the best way to mow a field...
   / let's discuss the best way to mow a field... #11
Rocket science is easy!
...It's rocket engineering that is the difficult part.
   / let's discuss the best way to mow a field... #12
Its mowing and not rocket science . mow a round on each end lay off a land and start . work left to right / right to left it really doesn't matter . just start on longest side
X2. .
   / let's discuss the best way to mow a field... #13
80%? Eh. It's "A Number" I suppose. Good as any! :confused3:
I'd guess in reality it's wide ranging +15% (65%-95%) depending on the size of the field and its geometry.
Here are some estimated efficiency factors for various implements from http://caes2.caes.uga.edu/engineering/handbook/documents/capacity.pdf. You could achieve 100% efficiency if you were mowing a single swath exactly the width of your mower around the circumference of a field under center-pivot irrigation. But given my age, I might have to allow for a bathroom break.:)
Steve
   / let's discuss the best way to mow a field... #14
IMHO spitting a field more especially a large field into 2 or more lands just creates ""more corners which requires more time"". Start at outside go round & round then when you get to the middle then mow the corners & your done.
   / let's discuss the best way to mow a field... #15
When I was mowing my 3 1/2 acre yard, I though about the same thing and my Navy background kicked in.
In a search and rescue scenario, you want to cover the search area as quickly as possible and leave no portion of the area un-searched.
When you have a large but defined area, the recommended search pattern is called "Parallel Search". So that's the pattern I used when mowing.
The problem is you need to be able to do a 180 degree turn in the width of your mower.
   / let's discuss the best way to mow a field... #16
If the field is round Thats an option. Every time I see someone mowing in circles when they are done it looks worse than stump whooped chittlens.
   / let's discuss the best way to mow a field... #17
..... Every time I see someone mowing in circles when they are done it looks worse than stump whooped chittlens.
That's a new one for me.:) Any photos of what they look like?;)
Steve
   / let's discuss the best way to mow a field... #18
Steve
if you know what chittlns are and what they contain its not hard to imagine that everything will be covered in SHYT
   / let's discuss the best way to mow a field... #19
I use NASCAR method ..........go fast and turn left!
   / let's discuss the best way to mow a field... #20
You know - I see/hear a lot of good ideas on how to mow. Except I sure don't want any "stump whooped chitlins" round here. I don't give a D-A-M-N how good they are. I got a good idea what it looks like also - I had an occasion to dispatch a raccoon with a big stick. It wasn't pretty and it smelled to high heaven.
John Deere 1025R (A53317)
John Deere 1025R...
2013 Haulotte 4527A (A57148)
2013 Haulotte...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2009 MULTIQUIP 25KW GENERATOR (A55745)
2009 MULTIQUIP...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
