Kubota B7800
/ Kubota B7800 #1
plumbed1
Edwards, Ca.
Kubota B7800
Hello and Happy Fathers Day. My Kubota B7800 has been a great little tractor. it is just now starting to show signs of wear and tear and I cannot go in reverse without pulling up on the brake handle located under the steering wheel. Is there an adjustment I can name to correct this problem?
/ Kubota B7800 #2
Hmmmmm..... I need a better description of the problem and your temporary solution??
/ Kubota B7800 #3
Both cruise control and brake are tied into the HST mechanism via linkages. You probably need to lubricate everything down there, especially if it hasn't been done before. I had to lube that stuff on my B at least once a year or things would stick.
/ Kubota B7800
The black cover under the dash seems to be drooping. When I need to reverse, instead of it being instant I need to hold the brake handle up before the reverse control pedal releases. Everything works it is just an inconvenience for me if I am going from forward to reverse while working the ground. Slows me up considerably.
/ Kubota B7800 #6
Thanks for that info ..
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
2013 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2013 International...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
2018 FREIGHTLINER M2106 DUMP TRUCK (A63276)
2018 FREIGHTLINER...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
