Kubota B7800
/ Kubota B7800 #1
plumbed1
Edwards, Ca.
Kubota B7800
Hello and Happy Fathers Day. My Kubota B7800 has been a great little tractor. it is just now starting to show signs of wear and tear and I cannot go in reverse without pulling up on the brake handle located under the steering wheel. Is there an adjustment I can name to correct this problem?
/ Kubota B7800 #2
Hmmmmm..... I need a better description of the problem and your temporary solution??
/ Kubota B7800 #3
Both cruise control and brake are tied into the HST mechanism via linkages. You probably need to lubricate everything down there, especially if it hasn't been done before. I had to lube that stuff on my B at least once a year or things would stick.
/ Kubota B7800
The black cover under the dash seems to be drooping. When I need to reverse, instead of it being instant I need to hold the brake handle up before the reverse control pedal releases. Everything works it is just an inconvenience for me if I am going from forward to reverse while working the ground. Slows me up considerably.
/ Kubota B7800 #6
Thanks for that info ..
MAC STRIPPERS POWER MAC JR LINE PAINTING TRUCK (A63276)
MAC STRIPPERS...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2021 CATERPILLAR 326 LONG REACH EXCAVATOR (A65053)
2021 CATERPILLAR...
2014 International PayStar 5900i T/A 24ft Flatbed Truck (A64194)
2014 International...
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
