Kubota B7800
/ Kubota B7800 #1
plumbed1
Edwards, Ca.
Kubota B7800
Hello and Happy Fathers Day. My Kubota B7800 has been a great little tractor. it is just now starting to show signs of wear and tear and I cannot go in reverse without pulling up on the brake handle located under the steering wheel. Is there an adjustment I can name to correct this problem?
/ Kubota B7800 #2
Hmmmmm..... I need a better description of the problem and your temporary solution??
/ Kubota B7800 #3
Both cruise control and brake are tied into the HST mechanism via linkages. You probably need to lubricate everything down there, especially if it hasn't been done before. I had to lube that stuff on my B at least once a year or things would stick.
/ Kubota B7800
The black cover under the dash seems to be drooping. When I need to reverse, instead of it being instant I need to hold the brake handle up before the reverse control pedal releases. Everything works it is just an inconvenience for me if I am going from forward to reverse while working the ground. Slows me up considerably.
/ Kubota B7800 #6
Thanks for that info ..
2014 Crossroads RV Elevation T/A 5th Wheel Toy Hauler Travel Trailer (A61574)
2014 Crossroads RV...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A65054)
2016 INTERNATIONAL...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
