Kubota B7800
/ Kubota B7800 #1
plumbed1
Edwards, Ca.
Kubota B7800
Hello and Happy Fathers Day. My Kubota B7800 has been a great little tractor. it is just now starting to show signs of wear and tear and I cannot go in reverse without pulling up on the brake handle located under the steering wheel. Is there an adjustment I can name to correct this problem?
/ Kubota B7800 #2
Hmmmmm..... I need a better description of the problem and your temporary solution??
/ Kubota B7800 #3
Both cruise control and brake are tied into the HST mechanism via linkages. You probably need to lubricate everything down there, especially if it hasn't been done before. I had to lube that stuff on my B at least once a year or things would stick.
/ Kubota B7800
The black cover under the dash seems to be drooping. When I need to reverse, instead of it being instant I need to hold the brake handle up before the reverse control pedal releases. Everything works it is just an inconvenience for me if I am going from forward to reverse while working the ground. Slows me up considerably.
/ Kubota B7800 #6
Thanks for that info ..
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
2024 Kubota SVL 75-3 (A64126)
2024 Kubota SVL...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
LOOK! (A63111)
LOOK! (A63111)
1996 International Water Truck with a Caterpillar Engine (A63688)
1996 International...
John Deere 7000 6R Planter (A66285)
John Deere 7000 6R...
