kobalt air compressor
/ kobalt air compressor #1
mechanic
missouri
Anybody buy a kolbalt air compressor from lowes. I was looking at the 60 gallon 3.7 hp 155 psi. It's made by campbell Hausfeld so I figure it might be as good as the others I've looked at. IR has a 3 hp also and I have heard complaints about the motor burning up. I've heard complaints about the VT 6275 campbell hausfeld 60, and Husky. So where do you draw the line. What's your views on these compressor.
/ kobalt air compressor #2
I've got that one albeit my model was made by Coleman in the good old USA except the motor is Mexican built. If you look at the Lowes' web site, there are 29 customer reviews. I do not use my compressor in a commercial environment and I don't believe it was designed for commercial usage.
I have had it for two years without issues and I keep the tank charged all the time. Most of my work is sanding, sand blasting, wrenching, and plasma cutting. It has no problems delivering the air I need for these operations, some of them running concurrent.
Can you tell me if you removed it off the pallet? I've had two 60 gallon air compressors and never had issues with either one of them. I also left them on the pallet and moved them to new shop buildings and left them of the pallet again. Never an issue. They are claiming you need to bolt them to the floor now. I've just seen this I've been looking for a compressor to replace the one I left in MIssouri. Does this compressor have directions claiming you need to bolt it to the concrete floor?
/ kobalt air compressor #5
That Puma is nice ! And made in the USA too for $529 I'm sure shipping would suck and you'd have to live close enough to pick it up yourself but still......
Steve
/ kobalt air compressor #6
Steve
Steve, the Puma is a nice compressor, but I think it's made in Taiwan, instead of the USA.
/ kobalt air compressor #7
I've had an Ingersoll Rand 3 HP 60 gallon upright air compressor for about 5 years now. I use the heck out of that thing and have had no problems with it other than the oil sight glass on the compressor leaking a little, but that was easily fixed with some pipe tape.
/ kobalt air compressor #8
I bought my Husky (80 gal tank) at HD. Its also made by Campbell Hausfeld. Been a couple years now with no problems. I drain the bottom at every use to remove any condensate built up. Mine has a built in regulator with a separate port that can use reduced pressure for spray painting etc. without affecting the full pressure ports. I took mine off the cheaply made shipping pallet it came on and mounted it to the heavy duty pallet my old one sat on for over 20 years. It sits in the corner of the garage and never moves an inch.
/ kobalt air compressor #9
I did, but the compressor is sitting on a rubber floor. My work shop has thick rubber floor work surface.
/ kobalt air compressor #10
Northern Tool's web site claims it is made in the USA. Do you think they are attempting to mislead us?
/ kobalt air compressor #11
I don't know. All I found in the manual with mine said Taiwan, but maybe they are now made, or partially made, in the USA. Look at the very bottom of this Puma Air USA catalog. Even though I had the same model PK-6060V, back then it was labelled as 6 hp and now as 3 hp. As you can see in that pdf, it shows peak hp as 6 and running as 3. Instead of Northern Tool, I bought mine from an industrial air place that made some of their own compressors as well as the Puma and the guy said they called it an "imitation 6 hp" motor and showed me their true 5 hp motors.:laughing: But he said they had some of those Pumas running in shops 18 hours a day and never had a problem with one. I bought it because I definitely wanted something that could run continuously for long periods of time for sandblasting, plus I used an air blow gun to sweep out my 40' x 60' shop; never did like using a broom. And I was in the business of repairing mechanics' air tools at the time.
You might also look at Pumaair.com.
When I had to move back to town and sell the place in the country, I used a real estate salesman who also owned a really nice ranch in the area; obviously has lots of money, and he bought that Puma air compressor from me himself.
/ kobalt air compressor #12
A lot of brands 'manipulate' their 'made in the usa' claims... mostly it is 'assembled in the USA'.
Take, for example Ingersoll Rand. They claim 'made in the USA', but the pump is made in China or India and the motor is made in from Mexico. It is assembled in the USA only!
If you are looking for real usa-made quality, get a Quincy. They are strong, reliable and 100% made in the USA. Check out the air compressor buying guide here, it covers a lot, including single-stage and two-stage, etc.
ps. or buy an older model. The old Ingersoll Rand Type-30 are legendary and still good quality.
Pawon
2017 Ford F-150 Ext. Cab Pickup Truck (A61572)
2017 Ford F-150...
2015 John Deere 323E Compact Track Loader Skid Steer (A66734)
2015 John Deere...
PORTA POTTY (A68842)
Unused 2023 Land Pride PFL3048 48in. Forks and Frame Skid Steer Attachment (A66734)
Unused 2023 Land...
UNKOWN NATURAL GAS GENERATIR (A67714)
UNKOWN NATURAL GAS...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
