Air Compressor Stalls Out
/ Air Compressor Stalls Out #21
119v on a 230v motor would be a BIG issue 😂
Something doesn’t make sense. A 230v motor wouldn’t even start if it only had 119v. Are you measuring L1 to L2? Maybe you’re measuring one hot to ground, or neutral.
Time to check how everything is wired
/ Air Compressor Stalls Out #22
I use the same outlet for my lathe which is 220v and it works fine. This is a strange situation. Time to call an electrician. Thanks
Did you manage to somehow tie into a neutral on the wiring of the plug instead of the other 120VAC split phase leg?
Because that is what this sounds like.
Don't keep running it, that is very hard on the motor at 1/2 voltage.
You need to get the full 230-240 VAC at the pressure switch. It sounds like a plug or outlet mismatch in terminals is going on here.
It may be time for an electrician if you are not comfortable tracing out the circuit. Better safe than sorry but should be basic AC troubleshooting to fix this.
Because that is what this sounds like. Don't keep running it until you get the full 230-240 VAC at the pressure switch.
I will verify that. Thanks
/ Air Compressor Stalls Out #24
check the amp draw on the motor while running
The problem was the plug wiring. I had the wires going into one hot, one ground and one neutral slot on the outlet. Once I switched it to 2 hot and a ground it worked great. Rookie mistake, but I am glad it works. Thanks to everyone for the input on this topic.
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
Danuser 3Pt Post Driver (A66408)
Danuser 3Pt Post...
Golf Cart (pictures to come) (A62679)
Golf Cart...
2022 Forest River GANS58SA 8ft. S/A Enclosed Cargo Trailer (A64557)
2022 Forest River...
2022 EZ-GO ELITE...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
