kioti 3520 start up smell
/ kioti 3520 start up smell #1
nitogranados
Kioti 3520
this may be a weird question. When I start my kioti , it almost smells like the exhaust has a sweet aroma almost like radiator fluid. I don’t know if this has to do with the newer technology and exhaust systems. But my older Tractor’s never smelled like this.
/ kioti 3520 start up smell #2
Is there any white "smoke" from the exhaust?
I would definitely keep an eye on the coolant level.
/ kioti 3520 start up smell #3
DPF will leave some weird smells indeed, but just in case, keep monitoring the coolant level for some time.
Check it with the engine cold and check at the radiator. Don't just look at the expansion tank as under certain situations, it can be misleading.
no white smoke at all, tractor has 85 hours on it
okay 👍
checked it and it’s filled to the top, so must be dpf. i guess im not used to the newer tractors
/ kioti 3520 start up smell #7
I used to have a 2009 VW Golf with 1.6 TDI engine a couple years ago. That thing would stink the garage with that terrible DPF smell for the entire day. That thing was absolutely awful.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JLG 2630ES ELECTRIC SCISSOR LIFT (A60429)
JLG 2630ES...
2016 INTERNATIONAL PROSTAR (A59904)
2016 INTERNATIONAL...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
UNUSED KJ K0720-7'X20' METAL FARM DRIVEWAY GATE (A60432)
UNUSED KJ...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60430)
2019 ATLAS COPCO...
