kioti 3520 start up smell
/ kioti 3520 start up smell #1
nitogranados
Kioti 3520
this may be a weird question. When I start my kioti , it almost smells like the exhaust has a sweet aroma almost like radiator fluid. I don’t know if this has to do with the newer technology and exhaust systems. But my older Tractor’s never smelled like this.
/ kioti 3520 start up smell #2
Is there any white "smoke" from the exhaust?
I would definitely keep an eye on the coolant level.
/ kioti 3520 start up smell #3
DPF will leave some weird smells indeed, but just in case, keep monitoring the coolant level for some time.
Check it with the engine cold and check at the radiator. Don't just look at the expansion tank as under certain situations, it can be misleading.
no white smoke at all, tractor has 85 hours on it
okay 👍
checked it and it’s filled to the top, so must be dpf. i guess im not used to the newer tractors
/ kioti 3520 start up smell #7
I used to have a 2009 VW Golf with 1.6 TDI engine a couple years ago. That thing would stink the garage with that terrible DPF smell for the entire day. That thing was absolutely awful.
(INOP) BROCE BW260 SWEEPER (A62129)
(INOP) BROCE BW260...
UNUSED WOLVERINE TDB-11-84W 84" QUICK ATTACH BKT (A62131)
UNUSED WOLVERINE...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
PALADIN GSS72-72" HYD BRUSH CUTTER (A62129)
PALADIN GSS72-72"...
2011 CATERPILLAR 299C SKID STEER (A62129)
2011 CATERPILLAR...
UNUSED SDLANCH DIAMOND PLATED PLASTIC MATS (A62131)
UNUSED SDLANCH...
