JD loader control repair
/ JD loader control repair #1
JoeArkansas
John Deere 5300C
After replacing the loader control pistons (spools) and after putting the assembly back on the tractor they seemed to be reversed even though I was careful to put the cables back on the same side as removed. Pushing the joystick forward now dumps the bucket instead of lowering the bucket as before. If anyone has had similar experience please tell me what you did to correct it?? Thanks,J
/ JD loader control repair #2
Go back and try again. You either crossed the controls or the hoses. If it works, only backwards on the controls you haven't damaged anything, just crossed something up.
/ JD loader control repair #4
Sounds as if hoses that lead to cylinders were attached to valve body incorrectly.
Thanks, ill try that.
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2012 FORD FOCUS SEL (A65054)
2012 FORD FOCUS...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
Land honor Mini Skid Steer (A60352)
Land honor Mini...
2018 MACK CXU (PINNACLE) (A65643)
2018 MACK CXU...
