JD loader control repair
   / JD loader control repair #1
JoeArkansas
John Deere 5300C
After replacing the loader control pistons (spools) and after putting the assembly back on the tractor they seemed to be reversed even though I was careful to put the cables back on the same side as removed. Pushing the joystick forward now dumps the bucket instead of lowering the bucket as before. If anyone has had similar experience please tell me what you did to correct it?? Thanks,J
   / JD loader control repair #2
Go back and try again. You either crossed the controls or the hoses. If it works, only backwards on the controls you haven't damaged anything, just crossed something up.
   / JD loader control repair #4
Sounds as if hoses that lead to cylinders were attached to valve body incorrectly.
Thanks, ill try that.
2015 KENWORTH T370 QUINT AXLE DUMP TRUCK (A45678)
2015 KENWORTH T370...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A45679)
2012 VOLVO VNL...
2013 Dodge Charger Sedan (A46684)
2013 Dodge Charger...
2008 International CF500 Electric Lift Service Truck (A48081)
2008 International...
1998 MACK CH613 DAYCAB WINCH TRUCK (A48992)
1998 MACK CH613...
2013 PETERBILT 367 DAYCAB (A48992)
2013 PETERBILT 367...
