JD loader control repair
/ JD loader control repair #1
JoeArkansas
John Deere 5300C
After replacing the loader control pistons (spools) and after putting the assembly back on the tractor they seemed to be reversed even though I was careful to put the cables back on the same side as removed. Pushing the joystick forward now dumps the bucket instead of lowering the bucket as before. If anyone has had similar experience please tell me what you did to correct it?? Thanks,J
/ JD loader control repair #2
Go back and try again. You either crossed the controls or the hoses. If it works, only backwards on the controls you haven't damaged anything, just crossed something up.
/ JD loader control repair #4
Sounds as if hoses that lead to cylinders were attached to valve body incorrectly.
Thanks, ill try that.
CAT 225BLC Excavator (A65579)
CAT 225BLC...
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
2022 EZ-GO ELITE...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
John Deere XUV835M (A64127)
John Deere XUV835M...
