JD 5403 engine block coolant drain plug
/ JD 5403 engine block coolant drain plug #1
redkar
JD5103, JD5403
I have searched the net and cannot find answer. Where is the engine block drain plug for coolant antifreeze? I see a bolt head on the left side of the engine near the fuel pump, but not sure that's it. TBN is a great site. Thanks.
/ JD 5403 engine block coolant drain plug #2
Welcome to TBN
Some photos or two of the "bolt" head that might be a block drain would possibly help someone clarify for you.
Try this link to see if it helps.
Thanks for the reply. The procedure in the link is in the owners manual. Removing the thermostat requires removing several other items. Not a quick, easy task. I was hoping to simply drain the block and the radiator, flush and refill coolant.
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
New/Unused ATS 13000 Pound Electric Winch (A65583)
New/Unused ATS...
NATIONAL CRANE NBT50 (A65643)
NATIONAL CRANE...
40' Shipping Container (A66285)
40' Shipping...
1988 Mack R688ST (A62679)
1988 Mack R688ST...
2004 Caterpillar 315CL Excavator (A64194)
2004 Caterpillar...
