JD 5403 engine block coolant drain plug
/ JD 5403 engine block coolant drain plug #1
redkar
JD5103, JD5403
I have searched the net and cannot find answer. Where is the engine block drain plug for coolant antifreeze? I see a bolt head on the left side of the engine near the fuel pump, but not sure that's it. TBN is a great site. Thanks.
/ JD 5403 engine block coolant drain plug #2
Welcome to TBN
Some photos or two of the "bolt" head that might be a block drain would possibly help someone clarify for you.
Try this link to see if it helps.
Thanks for the reply. The procedure in the link is in the owners manual. Removing the thermostat requires removing several other items. Not a quick, easy task. I was hoping to simply drain the block and the radiator, flush and refill coolant.
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
Vision 250/50R15 77D Golf Cart Tires (A65579)
Vision 250/50R15...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A65643)
2009 VOLVO VHD...
2022 EZ-GO ELITE...
