If it's cold where you live, what are you heating with and what is it costing?
   / If it's cold where you live, what are you heating with and what is it costing? #21
It's not the Artic here in NC but, it's too cold to be comfortable. We heat with wood with heat pump back-up... As for the cost:
Wood is free for the taking.
Truck: $35,000
chainsaws (plural) $1200
log splitter: $500 (got a deal)
tractor to load & move wood $25,000
Annual Fuel for above $200
wood stove insert $1800
Misc. costs $200
Chiropractor & Physical Therapist $233 (Medicare deductible)
We're comfortable... at 72-75 degrees
My trade is construction so I didn’t buy this to cut a few thousand dollars of firewood but I was thinking the other day how much money I was using to cut firewood lol. My more direct cost to cut my year supply of wood is a few hundred dollars of fuel plus the labor to do it. I sell a few cords a year and in past years I’ve sold considerably more to offset the saws and splitter cost.
   / If it's cold where you live, what are you heating with and what is it costing? #22
These are unique times here in NH - electric costs just went from .22/KWH to .34/KWH this fall over 50% increase from last year,
Who is your electric provider? We have Eversource, and the rate is .22/kWh (electricity only, not including "delivery" charges), though that's a bit more than a 100% increase :eek: from what it was 6 months ago. I checked pricing for "alternative providers" online, and they were within a couple cents of Eversource...not enough to make a noticeable difference in the bill.
To answer the OP's question, primary heat source is wood (woodstove in the living room) with a FHA oil furnace as backup. We rarely use the furnace...I don't even remember when we last filled the tank, it was at least 5 years ago, still ~75% full. We almost never go away in the winter so about the only time the furnace is turned on is in the spring or fall when the house is a bit chilly but not cold enough to warrant lighting the stove.
At my last house wood was mostly free, cut on my property but here it's mostly evergreens and/or trees like poplar. that are pretty much worthless as firewood. Much of it had been logged about 10 years before we moved here, so a lot is new growth. Most of the hardwood we have isn't easily accessible (steep slope or swampy). I'll buy grapple loads every couple years, then cut & split myself with the occasional downed tree or scavenged wood supplementing. One load is good for about 2½ years.
Having heated our home in Ohio with chunk wood from the property (we had 20 acres of woods and I cut was deadfall and dead trees), I don't miss it one bit. Storing wood inside in the basement where the forced air chunk wood burner was, always brought in sleeping bugs that migrated out of the splits and got upstairs plus cleaning out the ashes and disposing of them every other day or so and of course hauling the wood into the basement. With the biomass stove, all it takes is a 40 pound sack of pellets every day and ash cleaning is maybe a weekly deal and it has an ash pan so it's easy and I buy the pellets in full tons on pallets and they go on the barn and no bugs and my corn comes in bags as well.
My very good friend near Bangor Maine, just too an almost 100% increase in electricity costs from his electric provider. He heats with chunk wood (like a good Mainer does) but it still take electricity to run the circulator pumps and power the lights. Juice is getting pretty darn expensive lately. Diesel is through the roof up his way too. His diesel pickup is garaged and has been.
   / If it's cold where you live, what are you heating with and what is it costing? #27
We have 4600 square feet on two floors, the basement about 3 feet in the ground with a geothermal system that also heats the domestic water when the furnace is working for heat or cooling. We keep the house at 68 in the winter and 76 in the summer. The garage is 650 square feet and we heat it to 56 but do not use the air conditioning. Most of our power costs $.14 KWH at the higher level. Our highest bill ever for ALL electricity was $650.00 for two months in Dec./Jan. and $230.00 for two months July/Aug. A full year cost about $2600.00 last year. I can't be bothered to cut wood to try to reduce this by about $1000.00. My shop isn't finished yet. 1360 square feet with pex in the floor. I plan to hook up a homemade electric boiler and hope the costs for electricity aren't prohibitive. If the costs get too high I'm considering a waste oil boiler and sending some of the hot water to the house. After seeing what some other people pay for heating, I feel I can't complain.
   / If it's cold where you live, what are you heating with and what is it costing? #28
Wood furnace not stove burn around 5 cords starting mid Oct end May...back up electric.
   / If it's cold where you live, what are you heating with and what is it costing? #29
I live in Quebec, Can.
After reading some of the posts I feel much better with my heating costs which are all electric.
It has been a while since I've compared our hydro rates to other areas.
OK, Quebec generates a lot of electricity which we can even export.
On the other hand, where I live, we have frequent power outages so my generator running costs greatly offset any hydro savings, LOL.
   / If it's cold where you live, what are you heating with and what is it costing? #30
New Brunswick- north of Maine
Including finished basement ~4000 sq ft/lots of insulation (R2000 if you know what that is)
Geothermal HVAC & Air tight fireplace. Burn a few cord/year that I cut & cure for min 2 years
Not certain of electricity cost, but summer time ~$100 Cdn winter close to $200. Last month was $98
That includes lights, water (on well), etc.
   / If it's cold where you live, what are you heating with and what is it costing? #31
Your chart is a bit off on some fuels. For one, corn (12% or less) is not even close to the BTU output of hardwood pellets and the cost of coal has risen exponentially as of late, especially rice coal.
Not sure what you are disputing, I went and looked up soft and hardwood pellet btu's per ton.
And yes the cost of coal has risen I paid $450 per ton this year.
In most publications corn and wood pellets are about the same btu per pound
Fuel pellets are sold and tested be weight, so a 40 pound bag of softwood pellets equals a 40 pound bag of hardwood pellets.
  • A good quality hardwood pellet has about 8,000 BTU’s/lb- 320,000 per bag.
  • American Wood Fibers Ultra Premium Softwood pellets have about 8,700 BTU’s/lb- 348,000 per bag- 28,000 BTU more!
  • A good quality hardwood pellet has an ash content around 0.50%.
The combustion energy content of shelled corn is a critical factor in making energy comparisons of fuels. The energy content of shelled corn is not a constant value because of biological variability and management factors. Generally, the energy content of corn is in the range of 8,000 to 8,500 BTUs per pound of dry matter.
The standard moisture content of shelled corn is 15.5 percent moisture on a wet basis. This means that each pound of shelled corn will actually consist of 0.845 pound of dry matter and 0.155 pound of water. Using a median energy content value of 8,250 BTUs per pound of dry matter, the energy content of one pound of shelled corn at 15.5 percent moisture is then 6,971 BTUs (8,250 BTUs per pound dry matter x 0.845)
   / If it's cold where you live, what are you heating with and what is it costing? #32
Our house is Geodesic dome, with a half loft. It has substantial solar gain on clear days, even if its 45 degrees outside. Lots of skylights. 3,200 square feet. My area of the PNW through out winter stays around 42 daytime and 33 night time. Mostly on its own it will maintain 68 degrees. There are just a few weeks, in January and February, where things get below freezing on average. Outside temp, oddly isn't a major factor for a dome. What is a major factor is on cold rains, with out the solar gain. Since a dome is mostly a roof, with out an attic to lay down a huge amount in insulation, the water evaporation on the roof, transfers all the heat out of the house. The energy costs swing wildly according to season. I use three systems. One is the very expensive, electric hydronic floor heating.... That I think I badly designed. It takes at least two hours to feel any difference and sucks electricity, doubling the usual $88 a month total electric bill to $176 or so but the effect last for a few days. once the pad is heated. The other that we use in spring and fall, is the plug in radiant heaters. These bring the bill up to about 110-120 or so. And then there is the wood stove, that will heat the whole house, our wood is free, at little monetary cost aside from all the effort. It works out overal, but the swings in cost are big swings.
Actually, the realized BTU content of corn entirely depends on the moisture content. The drier it is the more realized BTU output there is. Just so happens I roast 9% corn whereas most coop corn will be around 14-15%. It has the be no higher than 15% to be tanked or it will mold.
...and softwood pellets deliver more BTU's per volume than hardwood pellets with Doug Fir being the highest. Been roasting pellets and corn for over 20 years now.
Corn has some less than desireable burning traits, mainly nitric acid vapor as it combusts or should I say carmelizes.. The nitric vapor is hard on a steel stove and hard on the venting as well even though the inside liner on pellet vent is stainless, eventually, the nitric will corrode it, especially if you don't purge the stove and venting prior to spring shutdown. Why the last couple heating weeks, I run straight pellets at maximum feed rate to 'cook' the nitric vapor out of the stove and venting.
Not disputing anything other than your chart shows a generalization and not specific constants.
I read that coal went way up on cost. Know a couple stoker stove owners.
   / If it's cold where you live, what are you heating with and what is it costing? #34
Last year I paid $380 ton this year $450 and I bought before the last price increase, I have heard rumors that it has actually gone down a bit at the mines now. Of course the dealers are all stocked up on the expensive stuff now.
I had looked at corn burners several years ago and went with coal.
   / If it's cold where you live, what are you heating with and what is it costing? #35
I'm just about the opposite. My wood stove keeps the place toasty in winter, yet in summer after working outside all day my AC keeps temps close to that of a morgue. 👍
   / If it's cold where you live, what are you heating with and what is it costing? #36
One thing I realized about pellet stoves is the usage rate is the same for both hardwood and softwood pellets because the auger speed determines the usage, not the energy level of the fuel.
   / If it's cold where you live, what are you heating with and what is it costing? #37
Wood from all tree species have the same BTUs by weight. The difference is the density of each.
   / If it's cold where you live, what are you heating with and what is it costing? #38
"Wood from all tree species have the same BTUs by weight. The difference is the density of each." -Jstpssng.. That is interesting. I believe you are correct. Softwoods you need a bit more, Hard woods a bit less. The hardwood we have here is Madrone. Madrone is worth 1/3 better then any other trees, but you gotta get the stove, and have a stove hot enough, to burn them. :)
   / If it's cold where you live, what are you heating with and what is it costing? #39
How ever the unit measure of CORD become the standard, did the heating world an injustice.
But then, a ton of fresh wet wood is no bargain either. ;-)
ps
I heat with wood. There is an oil fired boiler for domestic hot water. Even that is $100 per month.
Last truck load of logs went up from $750 to $900.
Over a year's worth, but it's getting harder to get a load in. Competition with the pulp buyers.
Two saws, both getting older.
New TW-2 last year. that was about $1400 with my TW-1 trade. The TW-1 was 10 years old. In ten years, I'll likely not be splitting on my own.
Like I said previously, if coal was available here I would have went with either a Heiser or a Key Stoker. It's not. Nearest dealer to me is 70 miles away. Corn is plentiful here and so is pellets. My corn is so plentiful for me, it's free. I believe Harman also makes a coal stove or did at one time. Problem with burning corn is, the unit has to be corn capable, that is, it has to have a stirrer (agitator) and the control board has to support corn as well. Most pellet stoves don't.
(15) WOOD PALLETS (A60432)
(15) WOOD PALLETS...
INGERSOLL RAND G25 GENERATOR (A58216)
INGERSOLL RAND G25...
UNUSED MINI EXCAVATOR QUICK COUPLER (A60432)
UNUSED MINI...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
GE WASHER & DRYER (A60432)
GE WASHER & DRYER...
pressure washer, and trailer (A56859)
pressure washer...
