5030
Epic Contributor
- Joined
- Feb 21, 2003
- Messages
- 24,785
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
I'll start it off by saying we heat with propane (Bryant Plus 95) for the house and in floor PEX (propane fired hot water heater in the shop, but we also heat with 2 biomass stoves, one in the house and one in the shop.
We burn primarily dried off grade seed corn (which I get for free) plus processed wood pellets. I mix the corn and pellets together and the stoves burn them
Each stove is capable of 80K Btu output though I rarely run them flat out and about the only time the central furnace comes on is when the heat load exceeds the output of the stove in the house. I do keep my in floor PEX system active all winter and hold the slab temperature around 60 degrees, I like warm feet when working in the shop.
My total biomass fuel bill is around 600 bucks (for processed wood pellets) during the winter and I usually consume one 500 gallon bottle of propane as well.
I pre bought propane this year at $1.99 a gallon and glad I did as propane here is at $265 a gallon presently and going higher.
Where are you at concerning heat and what do you use for fuel?
