Winches Hydraulic Winch
   / Hydraulic Winch #11
Needs a couple stab jacks too even make (at single line pull) a stand against a 40' hardwood trunk. Nice toy!
   / Hydraulic Winch
Thanks for all the compliments. The Sthil saw on the winch is a 064 that my uncle gave to me about 15 years ago. Before that, he used it to cut timber. It still runs as good a new one. In my opinion, you do not own a saw unless it is a Sthil. As someone mentioned earlier about the clutch, there is no clutch on this since it is pulled with a hydraulic motor. If the pulling resistance outweighs the pulling force, the pressure releif valve on the tractor opens just as it does on a loader when you try to lift too much. I originally was going to pull this with the PTO and slip clutch, but I would have needed to created a lot of linkage and it would have not looked as clean. The blade serves two purposes; First, I can sit it on the ground when winching. The weight of the pull burries the blade into the ground, which makes it very stable. I dont have to lock the brakes or anything. Just drop the winch on the ground and go to town. The other reason is to clear brush out of the way. I like to get as close to the tree as possible to limit the amount of cable to pull out.
   / Hydraulic Winch #14
Wow - nice unit. The design shows you put a lot of thought into it. Very well done. The equipment storage areas are a great idea. Did you use grab hooks or a slotted angle to hang the choker chains from?
- Marty
   / Hydraulic Winch #15
Very nice setup!
A question: what is the reason for the angle of the Ditchwitch ROP?
If you would be so kind, please post a picture of the top of the setup.
Obviously the sheave and support are there, but are some things that I
can't make out from the backside.
Nice job!
Thanks,
Barry
Golf cart (A56859)
Golf cart (A56859)
2011 TOYOTA Prius (A56859)
2011 TOYOTA Prius...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
Mini -Excavator Heavy Duty Rock Ripper (New/Unused) (A59225)
Mini -Excavator...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
