Winches Hydraulic Winch
   / Hydraulic Winch #1
jwbrown
Hamptonville, NC
Kubota L4740 GST w/ FEL, 1975 Ford 4000
I finally finished the hydraulic winch that I built for my 4740 GST. Overall, it works very well. I can winch a full lenght tree with no problems. The winch was built with an old Holmes wrecker winch, a ROP from a ditchwitch, a push blade from a wheel horse lawn tractor, some high dollar steel, and a little bit of amateur engineering. You will see in the photos that I bent one side of the blade a little. I have since straighted it back and added gussets on each side. Overall, I have around $1400.00. A new one will cost well over $4000.00. Hope you enjoy the pictures.
   / Hydraulic Winch #3
Cool, I like the storage bin, very nice job!!
   / Hydraulic Winch #4
That is a nice looking piece of equipment, looks good enough to sell in production.
Shane
   / Hydraulic Winch #5
Looks great!;) And by the position of the winch it looks like you could have even had it PTO driven as well. Great job!:D
   / Hydraulic Winch #7
Nice Work!....But why do you have a blade on it?
When the blade is lowered it will give added braking while winching...
   / Hydraulic Winch #8
Nice job John:
Does the winch have any provision for a slip clutch, say you hooked a log behind a tree while you were winching it in? My farmi will slip so nothing breaks.
simonmeridew
   / Hydraulic Winch #9
Very professional job.
It would look even better if your chainsaw was the same color.
   / Hydraulic Winch #10
Very nice job. Just a thought - some of the taller winches mount a snatch block and notched rail at mid-height so the top link doesn't have to take so much force drawing a full hitch.
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2016 TANKKO 130BBL VAC TRAILER (A52472)
2016 TANKKO 130BBL...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
New/Unused CFG Industrial NT18K Mini Excavator (A51573)
New/Unused CFG...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2020 JOHN DEERE 8R310 LOT NUMBER 210 (A53084)
2020 JOHN DEERE...
