Winches Hydraulic Winch
   / Hydraulic Winch #11
Needs a couple stab jacks too even make (at single line pull) a stand against a 40' hardwood trunk. Nice toy!
   / Hydraulic Winch
Thanks for all the compliments. The Sthil saw on the winch is a 064 that my uncle gave to me about 15 years ago. Before that, he used it to cut timber. It still runs as good a new one. In my opinion, you do not own a saw unless it is a Sthil. As someone mentioned earlier about the clutch, there is no clutch on this since it is pulled with a hydraulic motor. If the pulling resistance outweighs the pulling force, the pressure releif valve on the tractor opens just as it does on a loader when you try to lift too much. I originally was going to pull this with the PTO and slip clutch, but I would have needed to created a lot of linkage and it would have not looked as clean. The blade serves two purposes; First, I can sit it on the ground when winching. The weight of the pull burries the blade into the ground, which makes it very stable. I dont have to lock the brakes or anything. Just drop the winch on the ground and go to town. The other reason is to clear brush out of the way. I like to get as close to the tree as possible to limit the amount of cable to pull out.
   / Hydraulic Winch #14
Wow - nice unit. The design shows you put a lot of thought into it. Very well done. The equipment storage areas are a great idea. Did you use grab hooks or a slotted angle to hang the choker chains from?
- Marty
   / Hydraulic Winch #15
Very nice setup!
A question: what is the reason for the angle of the Ditchwitch ROP?
If you would be so kind, please post a picture of the top of the setup.
Obviously the sheave and support are there, but are some things that I
can't make out from the backside.
Nice job!
Thanks,
Barry
1R PLANTER (A52708)
1R PLANTER (A52708)
2023 Kubota U27-4 Mini Excavator (A55973)
2023 Kubota U27-4...
2014 Ford F-350 Pickup Truck (A55973)
2014 Ford F-350...
2015 FREIGHTLINER CASCADIA DAYCAB (A58214)
2015 FREIGHTLINER...
MASSAGE CHAIR (A58214)
LOT: (3) Shelves of Parts, Filters, Oil, Antifreeze (CONTENTS ONLY - ALL APPEAR TO BE UNOPENED) (A59076)
LOT: (3) Shelves...
