Help sizing hydraulic components for my home made mini skidsteer
   / Help sizing hydraulic components for my home made mini skidsteer #1
jonkreuz
Homeade mini skidsteer
Hi Guys! My name is Jon, this is my first time posting on here. For the last couple of months I have been working on my chassis and loader for my little homeade wheeled mini skid project. Its coming along pretty good, and now its time to start ordering hydraulic components. This is where I am hoping I can get some assistance from some of you who know way more than I do about these calculations. So what I have to power this thing is a 24 hp honda vtwin. I picked this because 24 to 25 hp seems to be pretty standard on the mini skid market for machines about this size. Thats all ive got so far is the engine, I now need to order a gear pump, 2 wheel motors, lift and tilt cylinders, hoses, valves, all kinds of stuff. My machine is going to work the same way most skidsteers work, or at least used to work. One hydraulic motor on each side will chain drive the tires on that side via sprockets.
I hope to achieve good torque as well as ground speed with the pump, hydraulic motor, sprocket combo I go with. From what I have seen online looking at these things, around 5 mph ground speed seems to be what to shoot for. Overall, I believe the machine is built heavy enough to be stable picking up somewhere between 600 to 1000lbs. Anywhere in there would be cool. Aside from that, If I could achieve somewhere around 11-13 gpm auxillary flow for attachements that would be awesome. So for anyone who knows or is willing to help, here are my main questions
1: I plan to use a triple stack gear pump, mainly just because everyone else is so im assuming that's the way to go. One pump for each drive motor, and one for boom and auxiliary hydraulics. Given what I hope to achieve with the machine, how would you go about sizing each pump?
2: Same goes for wheels motors. I believe the older wheeled dingos used about 30cc per rev wheel motors. Guessing ill need somewhere around there? But id hate to spend big money on motors and find out they won't work for me
3: Sprocket size. I have designed my hubs in a way where I change sprockets out If I don't like it, But a general idea of how many tooth sprockets to achieve the max power while still achieving the desired ground speed is needed.
4: hydraulic tank size? From what I've read I think its important to have extra fluid available so that It gets a chance to cool down before being recirculated again. An idea of how many gallons I should design my tank to hold would be great.
5: General hydraulic question. What all can I expect to get out of my 24hp engine hydraulic wise? Like If I wanted to shoot for even higher than 11-13 gpm aux flow, is this possible with this size engine? Or would doing so limit my ability to do anything else, like drive? I would imagine 11-13 gpm is fine, but hey if i can get more I dont want to limit myself. Not that I really expect to be able to run a brush cutter with this thing, but if I can someday then cool.
To whomever chimes in, I greatly appreciate it!!!!
   / Help sizing hydraulic components for my home made mini skidsteer #2
A basic rule of thumb is that 1 HP will provide 1 GPM flow at 1,500 PSI
Actual formula is HP = (GPM x PSI) / (1714 x efficiency)
For your travel drive a variable volume hydrostatic pump is more expensive but provides superior performance since you can vary the flow to control speed and does not require any directional valves or over running load protection to prevent machine from running away down hill. This is how most skid steers operate today but not sure on the small ones like Toro Dingo.
If using a gear pump for travel drive you MUST calculate HP requirements based on full flow and full pressure since you cannot vary the flow to change speed which will consume a major portion of engine power when pushing into pile of dirt and leave minimal HP for implement functions.
Typically you would start by calculating torque requirements for moving machine and load. Then size drive motors and gear reduction based on this torque requirement. Once drive motor size is determined you can then calculate flow requirements to achieve desired speeds.
Normally there is a lot of give and take to arrive at best solution with HP available, pump and motor size options etc.
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
2017 Liebherr L566 X Power Wheel Loader, PIN# VATZ1484EZB044020, Liebherr Turbo Diesel Engine, Cr... (A59076)
2017 Liebherr L566...
2019 Ford F-550 4x4 ETC37IH 37ft Insulated Bucket Truck (A56858)
2019 Ford F-550...
Caterpillar 262D3 (A57148)
Caterpillar 262D3...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
Evercraft 3-1/2 Ton Floor Jack, 12-Ton Bottle Jack (A59076)
Evercraft 3-1/2...
