HYDRAULIC LOGGING WINCH
/ HYDRAULIC LOGGING WINCH #41
nice work yoseph , have you given any thought to adding a fair lead set up, for odd angle pulling?
yes i am thinking to weld some steel chisel(teeth) to stop dinging as you said, today i crushed my Lovejoy plastic coupling, the torque output was too strong, if i could find a metal one that will be better, i don't want an elastic coupling i want a hard one. i don't think i will use a snatch block because my drum is approximatively at 3/4 the distance between the top link an the two lower links if i reverse my pulling rotation i mean wrapping from down not from up of the drum. also to increase the digging strength to the soil, because if i pull from the middle the anchor will slide horizontally rather than going down.
about the fair-lead i didn't received it yet but i think there will be any stress on the rollers will fix it in line with my drum.
one important thing i will say, if you plan to built something like that, think to purchase a hight torque hydraulic motor, most of those device don't need a hight flow, but they need a hight pressure, at 2000psi and over you will get what you want, as an example mine is working at 2000 psi and 2.5 gallon/min, if you increase the flow you will not increase the torque but you will get more speed, then in my case my speed is low and i manage my transmission to be 8.2:1, don't do something before examining the motor technical data specification and the hydraulic data of your tractor i mean pump flow an psi output.
thanks everybody
/ HYDRAULIC LOGGING WINCH #43
I have run into the lovejoy coupler problem on my log loader rotator head I finally am instaling a relief valve to keep from breaking them
2020 CAT 308 (A53317)
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
900 GAL SEWAGE VACUUM BED (A60736)
900 GAL SEWAGE...
2024 Bintelli ActivEV Pulse Electric Cart (A59231)
2024 Bintelli...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
