How to: Remove snow chains off tractor
   / How to: Remove snow chains off tractor #11
My pair fit nicely in a 5 gallon pail.
I unhook and drive off of them so they are laid out on the ground.
I deposit each gently so to not tangle them and hook the attachment hooks on the side of the pail.
Next I mix some oil with a solvent and splash that on the bunched (more like folded up) up chains, cover with a scrap of plywood and tuck the bucket out of site.
When I take them out in the fall they unravel nicely without any tangles making re installation easy.
   / How to: Remove snow chains off tractor #12
Took my chains off yesterday. I unhook the side and center links and drive out of them.
My chains are dry in the garage and I remove them while inside and drop them in the wooden crate they came in. They don't really need any rust protection. Next fall I'd rather deal with a bit of surface rust than a gooey oil coating or whatever when re-mounting them.
That surface rust go away when You drive little bit, I want harm to chains.
   / How to: Remove snow chains off tractor #14
Second language I'm sure and we understand. " I want harm to chains." should read. It won't harm the chains.
No it won't but a little used crankcase oil splashed over them when put away for the summer keeps them from becoming a rusty mess and does no harm.
   / How to: Remove snow chains off tractor #15
I hang the chains in the lower level of the shop. (bank barn style building)
Without the loader, it would be a chore getting the hook end up the 8 feet it takes. ;l-)(
   / How to: Remove snow chains off tractor #16
Yes when you have to move 14x28 (or bigger) chains around by yourself they are a real drag. A good excuse for needing that second tractor.
Yes, that's what I mean, last evening I was tired and write that on carelessly... ;)
   / How to: Remove snow chains off tractor #18
The slower they rust, the longer they'll last.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
2020 DRAGON ESP...
2013 Chevrolet Equinox LTZ AWD SUV (A56859)
2013 Chevrolet...
NEW HOLLAND HAY CUTTER (A58214)
NEW HOLLAND HAY...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
