Horse repower
/ Horse repower #1
kmiz
massey 65
I just repowered my horse with the Kohler ch-270, 7 hp, 208cc, which is an awesome little motor. That being said, has anyone else used this and or a similar size motor. I have clay and I feel that this motor is not sufficient. The old briggs 7 I/C would just bear down and dig deeper, this motor stalls out and even was knocking when tilling. And no the oil sensor is not the problem. I'm looking for a Honda gx 240 or 270 but they come with a 1" inch shaft. I see different people have put these on a troybilt so I was wondering what they did to make it work? Cut and rekey the shaft, bore out the pulley, is there an aftermarket 1" pulley?
/ Horse repower #2
My horse model has the Kohler 8 magnum and I think its 305 cc or so.
It doesnt bog. I think these new overhead valves lack the torque of the flatheads.
Was rebuilding the old motor not an option?
/ Horse repower
I believe they are rated high. This motor is 208cc and 7hp. they offer the ch260 which is 6hp and also 208cc's? The bottom line is a suitable replacement would be between 250 and 305cc's. These motors are small and just don't have the volume of the bigger motors I still have the 7hp briggs but I need to check around. One repair shop started at over $500 and he said that was just the parts???
/ Horse repower #4
That seems high but not actually looking the parts up dont know for sure.
What was the matter with the old motor?
/ Horse repower #5
Just looked and without knowing the exact model it looks like a complete rebuild kit is less than $100
/ Horse repower
I bought in 2012 and it ran like a champ till last year. I couldn't get it to run right at 3/4 -full throttle. rebuilt carb, no help. Then compression test was 80#.Then told it was that much which I thought was crazy, but he is a friend and I trusted him so I bought the Kohler command pro 7hp. I have always like Kohlers, right behind Honda's, but I always thought the b&s 7hp I/C was a darn good motor.
/ Horse repower
My motor: model v type
171432-0829-01
code 8801410
Where are you looking up the parts from, aftermarket or B&S. Thanks for your help.
/ Horse repower #9
I saw one kit at lawnmowerstuff.com for $65 or so that I think fits yours. They also have an oversize kit if yours needed boring.
/ Horse repower
I tried to contact Kohler to talk to a tech about that motor and they had some other company contact me. All I wanted to know is if the ch395 is available or could be made available in limited numbers in a 3/4" shaft for troybilt repowers. All I get for responses are, everyone is satisfied with the ch270, there must be something wrong with my machine. Look at troybilts today, the smaller Broncos, ponies come with a 208cc motor and the horse/big red come with a b&s 306cc 10hp motor, yet they tell me the ch270 is enough motor??? Although when I contacted Honda they said all gx240 and up motors are 1" shafts yet I see on small engine warehouse that they have a gx270-troy-34. It's getting real old fast trying to contact companies to talk to a tech and getting a call center that doesn't know crap!
/ Horse repower
Thanks, I just went to the site. Looks like I mite have another winter project now.
/ Horse repower #12
Thats what its all about. 😁
Most of the time when I get someone at tech support they have just learned the english and ifn the answer aint in their script book your outta luck.
Gotta love them offshore call centers.
But hopefully the rebuild works out.
/ Horse repower #13
Sounds like to engine is running too lean.
What does the spark plug color look like?
Remove the plug and post us a photo.
/ Horse repower
But can you buy a troybilt 2 speed pulley in 1". It's a double pulley with 2 different diameters.
/ Horse repower #16
Sounds like the engine is running too lean.
208 cc 7 HP Kohler is perfectly adequate for 20 inch horse, if it's running properly.
In my experience some of the new engines are fitted with too small carburetor main jet which makes the engine run at a very lean mixture and will bog down when full load is applied.
If that is the case, re-jetting the carburetor would be pretty low cost easy fix.
Remove the spark plug and post us a photo please.
/ Horse repower #17
/ Horse repower
Thx, I will check it out
/ Horse repower
I do agree with you that the motor should be sufficient. If I didn't have the larger 7hp b/s motor on there already I wouldn't have known there was such a difference. The current models come with a 208cc on the little broncos and a 306cc on the horse. that right there speaks volumes. What's the old saying? No substituion for displacement.
/ Horse repower #20
Makes me wonder what HP / Torque the Horse gearbox worm drive etc. are rated for?
I have had a 16 inch wide Pony Pro-Line with Honda GX160 5.5 HP engine since 1996 and it has never been lacking in engine power.
I wish it had more weight, bigger wheels and two speeds instead of just one speed, which is why I bought a 1976 20 inch wide Horse I, with 6 HP 221 cc Tecumseh HH60 engine little over month ago.
The HH60 seems to be perfectly adequate for this tiller and unlike the newer engines, both high, and low speed jets are easily adjustable on these older carburetors (on the other hand, the Honda GX160 in the Pony has newer needed any adjusting at all!). :D
CATERPILLAR C1.5 LITER (CONDITION UNKNOWN) (A68842)
CATERPILLAR C1.5...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
PORTA POTTY (A67714)
2018 32ft Forest River Lacrosse 3211RK T/A Travel Trailer (A66738)
2018 32ft Forest...
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
