Home-made attachments...
/ Home-made attachments... #81
hello,live in n.ireland,I've made several things that might be of interest to u ,not copies, just my own ideas, the 1 i have posted is a couple of attachments for a mini digger to leave it a bit handier to erect a fence on ur own im not an engineer and just made this in my spare time if u like it ill show more fotos of it and different stuff
It is the most brilliant I've ever seen. We definitely need to see a video of the masterpiece in use. And :welcome:
/ Home-made attachments... #82
here is some more fotos ihear the smoke alarm going so my dinner must be ready will put more photos of this and other stuff on later any questions
/ Home-made attachments... #83
really nice, I for one would like to see more
/ Home-made attachments... #85
/ Home-made attachments... #90
Very good work and very inventive. I trust that by you're saying "im not an engineer" you just mean that you don't have a school degree. Remember - not all engineers have a piece of paper declaring them engineers and not all of the engineers that have that piece of paper can actually engineer anything.
/ Home-made attachments... #91
this is what I've worked at for over 30 years
/ Home-made attachments... #92
This is very true.
/ Home-made attachments... #93
Here are a couple of things I either built from scratch or converted it into something I needed .
Land plane / road grader I built a couple of years ago . Added some additional bracing , modified the blade adjustment since these pictures were taken , but still no paint .
Leaf bucket I built a few years ago when the wooden one I had fell apart while dumping on the burn pile , thus it all burned !! :)
A 8 shank ripper that I made from a old single gang disk frame . What started out life as a 2 gang pull disk was converted to a single gang 3 point disk , then everything that was from the axle mounts on ward was cut off , braced , and the 4" x 4" x .25" tubing with shanks was added . Can pull it side hill or downhill with my TC30 , but uphill get's a little iffy when I try to go to maximum depth .
Fred H.
/ Home-made attachments... #94
Welcome to the TBN!
..and I love yourscreen name! I've been accused of being unstable more than once...
?..and no offense, but whatever you say, you sure engineered the cr*p out of that attachment and the fence you made with it.
Awesome job, but nothing I think I'd ever be able to replicate, much less use.
Again, nice work, and welcome!
Thomas
/ Home-made attachments... #96
Those are so solidly made!
T
View attachment 357039 View attachment 357040
View attachment 357041 View attachment 357042
View attachment 357043 View attachment 357044
Fred H.
/ Home-made attachments... #97
Wow that looks like my Shaver post driver look like a joke! Great build and nice fence!
/ Home-made attachments... #98
Hear is the forks I put together last month. I was fortunate to have found the actual forks in my local salvage yard. The rest is 3/8"x 4" flat stock. It makes handling logs easy.
/ Home-made attachments... #99
I'd never be lucky enough to find forks in a salvage yard. Nice Find!!!! :D
/ Home-made attachments... #100
great find on the forks and mount. looks like it should be on there.
1062 (A63291)
1062 (A63291)
Gehl Mix-All 95 Grinder Mixer (A64047)
Gehl Mix-All 95...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
Attention (A57148)
Attention (A57148)
2025 Hydraulic Plate Grapple Mini Skid Steer Attachment (A61572)
2025 Hydraulic...
Land Pride 80in Rotary Brush Cutter Tractor Attachment (A61572)
Land Pride 80in...
